N_Jay
Sep 13 2016, 07:36 PM
In the next few weeks I will be putting a (temporary) L-Jetronic 1.8 engine in my 914.
I am not sure I have a working bosch pump, so what is the preferred aftermarket pump these days?
Figure with all the EFI cars they should be easy to find, and guessing I will need a regulator to bring the pressure down to the right spec.
ClayPerrine
Sep 13 2016, 07:41 PM
Get an Airtex E8445 or equivalent. No regulator, other than the factory one is needed.
Available at your FLAPS.
Been running one on Betty's car for years. Works perfectly. Rob-O is running one on his L-Jet car.
Rob-O
Sep 14 2016, 08:01 AM
Yup, what Clay said. Works well. The inlet size to the pump is a little large if you're using the factory fuel lines sizes. But it's really easy to rectify the issue. The inlet comes as a brass fitting that screws onto the pump. You cut the barb off that brass fitting, then tap the hole left behind. You then thread a small Ford fuel filter into the tapped hole. It's a brilliant solution, really. The pump is an Airtex E8445 as Clay said. Tap was 1/8-27 NPT. I don't recall the fuel filter (but I bet Clay knows it off the top of his head). I used some self-tapping screws from the local hardware store and mounted the pump on the firewall.
I got all of the parts (pump/filter/tap) at the local O'Reilly's for ~$100. All of it was in stock (pump, filter) or hanging in the tool section (tap).
