Full Version: Targa Horizontal Trim
STL914
I need some HELP!!
I'm removing the aluminum targa trim from my car, both vertical pieces are off. Is there some trick to removing the horizontal piece from the targa bar? Do I need to delicately pry it from some mounting tabs?
I did a search on the site with no luck, so I decedied to post a request for help from you guys .
Thanks,
Porsche Rescue
It is held on with 3 or 4 spring clips. You carefully pull/pry straight back to the rear of the car.
McMark
jasons
You can actually reach up through the rear wheel well and pinch the clips so they pop out easier. You may not be able to do this for the one closest to the door however.
STL914
