Mikey914
Sep 17 2016, 01:17 AM
Got tired of looking for these some have them listed at $75 and 90, but no Who's interested? I know I need one soon!
914Next
Sep 17 2016, 01:46 AM
QUOTE(Mikey914 @ Sep 17 2016, 03:17 AM)
Got tired of looking for these some have them listed at $75 and 90, but no stock.
Not a particularly hard part to make, so Who's interested? I know I need one soon!
Count me in!
Tom_T
Sep 17 2016, 06:57 AM
Hey Mark,
I know that they needed to be the correct part number CHT for each MY & engine in order to work properly - i.e.: -037 for the `73 2.0, -043 for the `74 2.0 (maybe 75 & 76 GC 2.0 too??), etc.?
So will you be making them in the various "flavors" to match to the EFI systems in the different MYs & engines of the 914s, as did Bosch?
Tom
jim_hoyland
Sep 17 2016, 08:04 AM
Great! Gonna be ok for thT 1.8L L-Jet ?
hndyhrr
Sep 17 2016, 08:25 AM
me also, if for 70 1.7
Mikey914
Sep 17 2016, 10:03 AM
Well I have the spec for the 012, so I can make it work. I'm not sure the variations on the others, is it size or resistance? Anyone know for sure?
Dave_Darling
Sep 17 2016, 10:27 AM
They're physically the same, the only difference is the resistance/temperature curve. I think Brad Anders has some graphs on his website.
--DD
MartyYeoman
Sep 17 2016, 11:19 AM
Mark,
MCMark had an alternative design he worked out for these. It is supposed to be a more modern construction alternative. You may want to contact him regarding it before you dive into production.
Marty
Tom_T
Sep 17 2016, 02:23 PM
QUOTE(Dave_Darling @ Sep 17 2016, 09:27 AM)
--DD
IIRC it is those + the reaction time is slower on the -037 with the factory in-line resistor, but the ECU, MPS, etc. are all set up to work together correctly, while mixing components generally leads to running problems.
Probably Brad Mayeur or Brad Anders can explain the details better than I!
Tom
Mikey914
Sep 17 2016, 04:16 PM
QUOTE(Marty Yeoman @ Sep 17 2016, 10:19 AM)
Mark,
Marty
I'll check in with him too to see what he's got, thanks,
mark
Dave_Darling
Sep 17 2016, 10:51 PM
I was mis-remembering the CHT sensor info. What I found on Brad Anders' site is the following:
Sensor Temp = 39 deg. F
(ice bath with thermometer) Temp = 61 deg. F
(room temperature)
Temp = 210 deg F
(boiling water at 1000 feet altitude)
0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms
0 280 130 012 NA 2.85 K ohms 191.2 ohms
0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms
Not a chart, but a table. It comes from about 3/4 of the way down this page:
http://members.rennlist.com/pbanders/DJetParts.htmThe ECU page (http://members.rennlist.com/pbanders/ecu.htm) has charts showing voltage on one specific point inside the ECU versus CHT resistance. That may have been what I was remembering.
--DD
euro911
Sep 17 2016, 11:52 PM
So are you probing
the community?
I'll probably need a spare for the white car's 1.7L (1.9L)
Mikey914
Sep 18 2016, 12:43 AM
Well looks like there is enough commonality that they may be interchangeable, but not identical based on this -
Available new. The ...012 sensor is in short supply. Either sensor should work OK.
I'm looking at doing these again because I need them. Offering up the GB to those that are interested, but may raise the price to $75 after the GB if there's not much interest on these.
I did ping McMark on the phone today, but will follow up if he has a better answer. I may have located suitable materials for the build but can't check til Monday.
I don't have much of a choice as I do need one, so I will be working on a solution one way or another. Just really surprised that there's not much interest.
McMark
Sep 20 2016, 08:14 PM
I forwarded my info to Mark so he can proceed with this.
If you're car doesn't run well until it warms up, you might have a CHT issue. Any stock FI car that's working correctly should run as well cold, as it does warm.
Mikey914
Sep 21 2016, 12:17 AM
SO,
As noted we will be making the Original Customs version of these. They will be 3-4 weeks out. I Like what Mark had going with these and we can make these available again.
The key here is we need some quantity to get the price down, so hopefully there is enough demand to make these pencil out. Right now the only sources that "say" they have them are at least $80.
The discussion I had with Mark was that most people don't realized these have failed as think as it's an old car it will run a little rough until it warms up. They just live with it.
We will be doing a diagnostic video (once my car is back together to show you the effect of the failed one I have and the improvement. There is a good possibility that a few could benefit from having these and don't realize it.
SO if you want in on the GB price you will need to bump the thread to get the code when ready.
Given the costs these will be about $60 after the GB
SO whos' in?
euro911
Sep 21 2016, 04:05 AM
Yep, need at least one here
enikolayev
Sep 21 2016, 06:37 AM
Count me in for one as well.
DRPHIL914
Sep 21 2016, 06:41 AM
I will take 2!
Java2570
Sep 21 2016, 06:56 AM
Put me down for one!
Mueller
Sep 21 2016, 08:08 AM
I'm in for one, any discount if I machine my own housing?
914_teener
Sep 21 2016, 08:24 AM
Mark.....I have one of the Originals that McMark built in my car. It runs
Flawless.
It has a discrete ground wire which I would recommend.
I.m in but IIRC the resistance values coincide with which ecu it is paired with.
I am definately in for my D.jet 2056 I am working on.
jim_hoyland
Sep 21 2016, 08:35 AM
I'm in too and want to support this
DRPHIL914
Sep 21 2016, 09:44 AM
QUOTE(Philip W. @ Sep 21 2016, 08:41 AM)
I will take 2!
if they are spec for the 2.0 ....
Shadowfax
Sep 21 2016, 12:31 PM
QUOTE(Philip W. @ Sep 21 2016, 10:44 AM)
Me too. In for 1 on a '74 2.0 D-Jet.
CMONNETT
Sep 21 2016, 02:27 PM
I'll take three for a 2.0
Thanks,
Mikey914
Sep 21 2016, 10:15 PM
Thanks
I will update as this progresses.
Mark
Mike D.
Sep 21 2016, 10:29 PM
I'm in for 1!
mangrum
Sep 22 2016, 07:01 AM
1 for me please.
ThinAir
Sep 22 2016, 10:00 AM
I'm in for one.
metalmorphosis
Sep 22 2016, 10:56 AM
I'm in for one '73 1.7
second wind
Sep 22 2016, 01:07 PM
QUOTE(Mikey914 @ Sep 20 2016, 11:17 PM)
SO,
SO whos' in?
The way I am reading the thread is that there is lots of interest?! I want one for my '73 2.0 but I want the correct one, not a tweaked one. Build it and they will come.
BTW....I think all of us teeners will buy anything electrical that is an improvement over forty year old technology.....kind of like a knee replacement. Thank you!
Eric_Shea
Sep 22 2016, 03:07 PM
six
luskesq
Sep 22 2016, 04:05 PM
One for me please,
Keith
EdwardBlume
Sep 22 2016, 04:58 PM
I'm in for a 74 2.0 becoming a 2056.
turk22
Sep 22 2016, 06:49 PM
I am in for one, I need the 73 2.0 L specs
Its my understanding that they are NLA and have the 0 280 130 017 P/N
According to Brad:
"The 1973 2.0L's came with the:
0 280 130 017 head temperature sensor,
039 971 762 A ballast resistor,
0 280 100 037 manifold pressure sensor, and the
022 906 021 E version of the ECU.
This set of components must be used together. "
zambezi
Sep 22 2016, 06:54 PM
I'm in for 1. '73 2 liter.
Jim
warrenoliver
Sep 22 2016, 08:01 PM
I'm in for one for a '73, 2.0.
Thanks
Yanlx
Sep 28 2016, 12:17 PM
5 for me please 73 2.0
thanks
MartyYeoman
Sep 28 2016, 01:54 PM
Add my name to the list for one.
Can you provide some details regarding the proposed new design and how it might be customized to specific injection systems, engine sizes and model years?
Thanks, Marty
Mikey914
Sep 28 2016, 03:08 PM
Testing the parts now. But no, stock only for these. We could do others possibly, but on this stock only.
second wind
Sep 28 2016, 04:21 PM
Hey Mark.....so only 012 and not 017's?
JeffBowlsby
Sep 28 2016, 05:13 PM
I am down for 2 of the 012 Mark.
euro911
Sep 28 2016, 06:33 PM
Jeff, off the top of your head, what would a 1.7L need?
... and would punching it out to a 1911 change anything?
StratPlayer
Sep 28 2016, 06:36 PM
1 012 for me please
Mikey914
Sep 28 2016, 07:20 PM
QUOTE(euro911 @ Sep 28 2016, 05:33 PM)
I do have some 1.7 heads I can check.
JeffBowlsby
Sep 28 2016, 07:31 PM
A 1911 is a custom set-up so I cannot help you there.
Mikey914
Sep 29 2016, 01:28 AM
QUOTE(second wind @ Sep 28 2016, 03:21 PM)
This thread is 012 only. It's dialed in, and looks like we will start having parts ready in about 10 days,
Again you guys know how I work, if the numbers grow the cost will go down.
I was planning on running 100 units, but looks like I may be expanding production.
RohJay
Sep 29 2016, 02:14 AM
Please count me in for ONE. Thanks
McMark
Sep 29 2016, 07:19 AM
This CHT should never be used with the 73 ballast resistor. If you have the ballast resistor, it needs to be removed.
But then, you should only have the ballast resistor if you have a complete, actual, confirmed and complete set of 73 2.0 components (ECU, MPS, etc).
pch1north
Sep 30 2016, 01:02 AM
QUOTE(Mikey914 @ Sep 17 2016, 12:17 AM)
I'm in for 2
74 2.0
