JoeD
Sep 18 2016, 03:23 PM
QUOTE(poorsche914 @ Sep 18 2016, 04:28 PM)
"Owned one in the late 70ies. Bright yellow with T tops. [...] Was fairly fast'.
T-tops? Fast? Huh.
(Although I guess if it was a -6 or maybe even a 2.0 it could have been "fairly fast". Thus far I've only ever driven a very un-fast 1.7...)
injunmort
Sep 18 2016, 03:28 PM
a well meaning bunch, i am a member on that board as well. having said that, most of them know as much about british motorcycles as they do about 914's. these are the same guys that throw away the original amal gp carbs off the goldstars and internationals because they run better with concentric. which is not true btw, gp just harder to set up correctly.
billh1963
Sep 18 2016, 03:58 PM
One guy posted:
Both the 914-6's and the 911's had bad understeering problems due to the added weight of the six cylinder engine. The 914-6's got beefed up suspension and the early 911's went to a longer wheel base. Adding a V8 I think would make it a death trap.Then someone said:
You mean oversteer ?So the guy doubles down...LOL
No, understeer is what I meant. When you turn the wheel but the car doesn't turn. In this case the added weight going forward didn't want to move when you turned.
injunmort
Sep 18 2016, 06:23 PM
ah, i have a '71, a '72 and '74, in the last year, i have cut up a '71 and a '73. i am unfamiliar with this vw emblem area you refer, please embellish for those of us that are less enlightened.^
