QUOTE(rruffer @ Sep 18 2016, 04:27 PM)
My completely stock '76 had some constant throttle surging. The TPS circuit board looked worn, and the problem went away when I disconnected the plug to the TPS. So I installed a new TPS circuit board, calibrated it (using the resistance test and multiple tweak-then-test drive attempts), and the surging is worse! I disconnected the TPS again, and the cars runs great. No backfires--just a slight lag on throttle pick up from idle. Much easier to live with than the surging.
So my question is whether I really need the TPS? Any harm with running it permanently disconnected? I can play with it more and maybe try a new circuit board, but should I bother?
Thanks!
If you don't care about the decrease in power under acceleration, you don't have to use the TPS.
Your surging problem may be due to other causes than the TPS. I was convinced about 6 months ago that my TPS was faulty and causing irregular surging that I noted. Turned out it was a poor connection between the CHT spade connector and the wiring harness. Because the spade connector in the harness is hidden deep inside the plastic shell, it's easy to think you have it connected correctly when you actually have it trapped between the plastic and the connector. Once I finally got it right, no surging.
It could also be ignition problems, such as a sticky points plate. Regardless, make sure that the TPS is actually the source of the problem before disconnecting it.
