QUOTE(Mike Fitton @ Sep 18 2016, 05:47 PM)
S**t do I have to pull the front bumper to replace a burned out fog light bulb on '70 914-6?
Pull the fog light grille out, you can then access the whole fog light assembly. Pull out the top black surround. To do that there is little thingamajig held by a little screw just above the light mount, unscrew that screw, the thingamajig will move out and then you can pull out the top black surround and keep on removing parts until you see the bulb.
An easier way is to pull the whole assembly after you pull the fog light grille out and you can work on it on a bench.
Hope this helps.
