Full Version: Relay board question.....
Tjmrfe
Hey Guys,
1975 1.8 F.I. (Recently purchased)
I'll make it short...fuel pump isn't coming on, no voltage @ pump...so....I trace it as per (Bowlsby and my trusty F. I. Troubleshooting Manuel) and it says....check the dual relay located @ the driverside engine compartment.
And there to my amazement is this ratty looking "relay board" filled with mouse droppings etc. and I think, cool!! biggrin.gif This I can fix..
as per all the info I found, there should be a small round relay plugged into position #3 for the fuel pump...and......there isn't? WTF.gif
Only one in position #4? So....I pull it out, cleaned up the relay board,
(and I replaced the fuse, which was good)
and ordered a few round relays...
Now, can someone tell me, is the info I found, on multiple sites wrong? Should my FP run off relay #3? And since I bought a few spares, can I keep them in the other empty relay sockets there?
And does the voltage regulator relay have anything to do with this?
Thanks...Terry.
timothy_nd28
Relays and fuses on relay board do nothing for the Ljet. Also, the only time you will see voltage at the fuel pump is when you turn the key to start, or when the flap inside the air flow meter is deflected enough to engage the fuel pump trigger
Tjmrfe
QUOTE(timothy_nd28 @ Sep 19 2016, 09:32 AM) *
Ah ha!
That explains a lot...thank you, when my key is on, there is no fuel pump voltage...that's what lead me to the relay board in the first place
I'll look further. Thank you.
timothy_nd28
Have someone turn the key to start while you are measuring voltage at pin 88d at the dual relay. If you have voltage here, then you need to check the ground at the fuel pump. If you have a solid 12volts at the wires of the fuel pump, then your pump is either seized or electrically open and it's time for a new pump.
ndfrigi
Terry, you're in good hand with Tim! He did help me on my 75 1.8 FI. He know all the details of it. Thanks again Tim!
Steve_R
Hi Terry,
I attached a fuel pump trouble shooting check list. Scroll down to see the pictures.
If you start at the top and work your way down you will be able to find the problem.
Steve
timothy_nd28
agree.gif this is a good flow chart. But this only works if you have a Djet
Tjmrfe
QUOTE(timothy_nd28 @ Sep 19 2016, 12:42 PM) *
Thanks so much...
I'm getting no voltage @ pump with key on...so, I started to back trace, and was thrown off by my not understanding that the relay board was for D jets, headbang.gif
I'm gonna try again with the new info. You provided.
Appreciate your time..i needed exactly what you gave....the proper info. Thank you for providing that...
I'll check back with the solution!
