neo914-6
Apr 16 2005, 11:01 PM
Don't say to "baffle" noise.
These are nice large diameter competition headers and It took alot of time getting them out... couple of weld beads on the inside were hard to grind down w/o a dremel.
Mueller
Apr 16 2005, 11:03 PM
it's a muffler of sorts that fit's inside the header....
messix
Apr 16 2005, 11:11 PM
muellers right.
your doing good by getting rid of them. defeats the effect of the collector.
what are they going into?
neo914-6
Apr 16 2005, 11:49 PM
QUOTE (messix @ Apr 16 2005, 09:11 PM) |
muellers right. your doing good by getting rid of them. defeats the effect of the collector. what are they going into? |
Into my V8 conversion, replacing my old blackjack rusty headers.
It just seems odd someone would buy competition headers and go ahead and restrict them.
messix
Apr 17 2005, 01:03 AM
well stupid is as stupid does.
do you know much about headers? collector extensions and such.
914GT
Apr 17 2005, 09:15 AM
Maybe they're not as restrictive as mufflers when run with a straight pipe, but I bet they're still noisy.
scotty914
Apr 17 2005, 09:21 AM
i wonder if they are used to help even out the pulses from the cylinders and give a smoother flow
SLITS
Apr 17 2005, 10:11 AM
An open pipe can overscavenge the cylinder, causing the unburnt air/gas charge to go down the pipe instead of "staying" in the cylinder (also has a lot to do with the cam profile too).
All cars require some amount of backpressure in the exhaust system to run correctly unless your a WOT drag machine. This is either accomplished by length and bends or baffles.
It takes a dyno to find out what the optimum is...period.
Those pipes are real short.
messix
Apr 17 2005, 04:24 PM
not trying to sound like a know it all....but theres some missinformation here. [B]popular hot roddings may issue has the best and clear laymans explanation of modern exhaust design. mostly aimed at v8s but will work for any engines.
it's very difficult to "over scavenge" an engine with collector extentions,there tuned to the cam and heads rpm range to maximize torque. baffles in the collector do nothing but ruin the performance gains of headers. in your using baffles in collectors to tune the engine the pimary pipe diameter is way off. consider your lawnmower engine with a over sized exhaust 2" pipe. just loud!
check out that article
Troy
J P Stein
Apr 17 2005, 05:22 PM
QUOTE (messix @ Apr 17 2005, 02:24 PM) |
Troy |
You sound OK to me
