EdwardBlume
Sep 22 2016, 01:03 PM
I've been working on Dads car and I'm about to move on to the rear trunk. The battery side has been raised annoyingly for years and I want it fixed.
The trunk hinge pivot is loose on the offending side.
The spring / torsion is disconnected.
I have a newer latch spring.
I have the bolt on latch hinge replacement.
The issue?
I can't tell if the issue is the hinge, the trunk (i.e. Bent), the latch, or a combination?
Anybody been down this road before?
Millerwelds
Sep 22 2016, 01:23 PM
I suspect gravity is causing it to lift like that. Perhaps flip it onto it's wheels and see if the lid settles.
cary
Sep 22 2016, 07:17 PM
The pivot is what sets the level. Being disconnected and are broken could have tweaked the left hinge, which could be adding to you lift. Making it worse.
You need to get the pivot replaced to get the process started.
http://www.914world.com/bbs2/index.php?s=&...t&p=2396818
Larmo63
Sep 22 2016, 07:32 PM
Getting both of the hoods just right is frustrating.
JawjaPorsche
Sep 23 2016, 03:01 AM
I say do the best you can and don't sweat it.
Twenty years ago my driver's pivot came off. I had it rewelded. The welder liked my 914 so much he did not charge me. When I replaced my trunk it was a tad higher (2 mm). After figuring out the cause, I realized I would probably be the only one to notice it.
sixnotfour
Sep 23 2016, 03:46 AM
Perry Kiehl Clone
Sep 23 2016, 06:26 AM
You've got to fix the pivot location, as it's gotten raised up from pulling loose.
rgalla9146
Sep 23 2016, 08:49 AM
QUOTE(RobW @ Sep 22 2016, 03:03 PM)
The issue?
At some point you'll probably have to look at it and use some common sense.
amfab
Sep 23 2016, 09:05 AM
I just went down that road. Replaced mine with:
http://www.jwesteng.com/shop/914/10-914-re...runk-pivot.htmlSeems to be the best solution.
-Andrew
cary
Sep 23 2016, 09:23 AM
Whether you go with a weld in or JWest pivot. After you get the previous welds ground down. Check to make sure the parent material in the tub is in good condition. It's taken 40 plus years of debris being thrown at it in the fender wheel.
EdwardBlume
Sep 23 2016, 11:23 AM
QUOTE(cary @ Sep 23 2016, 08:23 AM)
Great point. This area was rebuilt years ago so the area is in really good condition. The drivers side got welded 15+ years ago but then the pass gave way.
cary
Sep 23 2016, 12:55 PM
Giving each pivot 3-4 drops of oil every year needs to become part of our maintenance plan. One side seizes up, and the other doesnt. Then you have the leverage of the big hood. Then pow, pivot gets ripped out.
EdwardBlume
Oct 8 2016, 04:21 PM
Its fixed now.
"Someone" disconnected the torsion bars and the ends were sticking straight up and keeping the trunk from sitting down. Stupid driving around like that for years....
I just pulled the bars out....
I shimmed the trunk up slightly and aligned the engine lid while I was in there. Now I just need trunk shocks...
EdwardBlume
Oct 8 2016, 04:23 PM
As she sits now...
Millerwelds
Oct 8 2016, 06:25 PM
QUOTE(RobW @ Oct 8 2016, 03:23 PM)
As she sits now...
See, back on its wheels and now it looks fine.
