QUOTE(sixnotfour @ Sep 23 2016, 08:56 AM)
money is always another factor..
All the above suggestions are very valid. How are you going to utilize it. Street, DE or some track time.
One other point mentioned above, how much money are you willing to support this decision. A used factory 901 / 911 LSD price point is approximately $1000 to $1500 - not including a rebuild. A new Guard will run you approximately $2800 to $3000.00.
Then you will need to have someone with the appropriate tools to set up the side / back lash / pinion spec..
Unless you have the appropriate tools, you will need to factor that in to the cost too. Oh, I believe one "can " set up these specs to "almost " spec. But for me, I rather use actual gages vs the other methods.
Just my .02
Good luck
