QUOTE(veekry9 @ Sep 25 2016, 10:56 PM)
Without this turning ugly, I suggest that you Google "magnesium fires". If you go back to the early days of the Beetle, VW used magnesium for its cases. The magnesium did not "spontaneously combust". Fires usually started from other faults such as fuel leaks or electrical fires. Once the engine saw fire, the magnesium would combust. I saw one burn like that when I was in college back in the 60's. And, water will not extinguish a magnesium fire. You let them burn until they run out of fuel. Or, you can foam the fire, though I never did witness that.
And, I believe that VW went to aluminum because it was less expensive than magnesium, and more stable. Not for its combustibility as you pointed out.
It is my understanding that this was part of the 1955 Le Mans disaster as well. The Mercedes that Levegh was driving was completely destroyed and scattered parts throughout the crowd, killing 80+ people, but the frame of the car, or significant portions of it were magnesium. As the (few) medics on hand tended to the crowd, the fire marshalls tended to the car which was already on fire. They sprayed water on it and it exploded into a white-hot fireball, making matters worse. All the while cars were still flying by at 150+ mph. Scary times those were.
