This car is newly completed and never raced. This car has to go to make room for the next project. Priced to sell $7950.
This car comes with a stock 1.7L Porsche engine ready to take on the track for track days. I recommend you run it like this so that you can learn the car before you start to add stuff to the motor. This car is already loaded for bear and can get away from you if you have never raced on a track before.
New 914 rear rotors drilled and five studs added by PMB Performance
New 914 front rotors drilled and tapped to 5 bolt pattern
New BMW 320i front brake calipers
New Porsche 911 rear calipers By PMB Performance
New 19mm master cylinder
New Coil over Bilstein racing shocks in the rear
New Dual downdraft Weber 40 IDF carbs
New Autometer racing tachometer with shift light
New Tangerine Racing full roll cage
New Holley racing fuel pump and regulator
New 5 point harness
New Turbo tie rods
New Kirkey 17" race seat
New shift linkage bushings
New rear wheel bearings
New front lower ball joints
Rear hubs drilled to 5 studs
Set of Porsche 944 cookie cutter wheels
Front adjustable sway bar and rear stock sway bar
15 gal ATL fuel cel
Master electric kill switch on dash
Oil temp gauge
Side shift transmission
Kerry Hunter racing headers with Supertrap exhaust
Front mounted RX-7 aluminum oil cooler with steel braided oil lines
Custom fiberglass oil cooler shroud
Fiberglass hood
Fiberglass front and rear bumpers
Custom fiberglass windshield valence
It needs a fire system installed to be VARA/SCCA race legal. I can install this if needed.
Spares:
Two core engines. One is complete core motor and the other is in pieces. I will throw these in for free.
I have the metal hood. I will throw this in for free too.
One set of Porsche 5 lug phone dial wheels with shop tires mounted.
Car is located in Ridgecrest, CA
