QUOTE(gms @ Sep 30 2016, 11:16 AM)
Glad to see you back on track, if you miss the Oct 7 race maybe you can make it to
That Looooong Race ?
Been stuck in the garage for the last 7 nights and haven't stayed up to date on the thread....
Engine is built on an early aluminum case. 2.5 short stroke. More or less same engine I had in there, less the damage from rod bearing failure. Previous motor expired after only 8 hours. Yay.
Click to view attachmentHad to replace the crank and rods due to damage. While you're in there syndrome set in. Upgraded to Pauter rods, Aasco springs, supertec flowed oil pump and a bunch of things I've certainly forgot about after a couple years accumulating parts. Naturally with bearing fragments everywhere in the oiling system I had to make new
Lines, replace the cooler, etc.
