914pipe
Jan 4 2017, 08:59 PM
QUOTE(flmont @ Dec 30 2016, 07:59 PM)
Now that I have my harness back Thanks Jeff,..I would like to know how others have installed thier's its bigger that I thought it would be,..and also what is this item that has the bracket attached and where does it mount ??
Click to view attachment Thanks Frank
The bracket thingy is the coil igniters....
914pipe
Jan 4 2017, 09:04 PM
QUOTE(flmont @ Dec 31 2016, 12:07 PM)
And last Q for now, How do I hook up this water line,.just run a jumper line ??
Click to view attachment Thanks Very Much !! Frank
I cap them, but is recommended to simulate the heater core circuit by a bypass line and is also recommended to place a vent valve (to leave no air trapped).
flmont
Jan 12 2017, 08:52 PM
I got lucky,..car 2500.00, engine with a 100k miles,trany adapter kit,transmission,and harness = 1500.00,.shipping to me 350.00,.then,.Radiator system and lines installed 1300.00,.finally I had to send the harness out to make sure it was terminated correctly,and fan harness that totaled 650.00 ,..So ,..total so far with some Misc. items about 6650.00. over a 2 year period.And I now need a engine mount that will total 300.00,..then exhaust system yet to be fabbed ,I have a 911 banana style muffler I intend to use also,..so now total is about 7K...FM
flmont
Jan 12 2017, 08:54 PM
And Thank U,... 914pipe
flmont
Feb 14 2017, 10:17 PM
when trying to install the fuel pump for my 3.3 build,..I have only found 1 factory wire in that compartment, Do I simply use a ground wire to the lid or body from the fuel pump it self,..?? TIA Frank
Chris H.
Feb 15 2017, 07:39 AM
I'll look today Frank. Happen to have my fuel pump cover off. Long story involving me dropping my phone down the space between the tank and the body
flmont
Feb 15 2017, 11:00 PM
Oh...Great Thanks !!! Frank
Chris H.
Feb 19 2017, 03:31 PM
Hi Frank,
I had to take my tank out today, so here's a nice pic for you.
Click to view attachmentAs you can see there is a ground wire connected to the pump, then connected to a spade attached to the body under the tank. If your spade is missing just ground it well to the body.
flmont
Feb 21 2017, 06:58 PM
OH..Ok,..Damn that blows ya had to pull the tank,..damn phones,..!! Thanks,..
I hate to ask I will be needed how to connect fuel lines to engine advice...Soon...Thanks !!!! so much...Frank
Chris H.
Feb 22 2017, 11:21 AM
No a problem. Very easy to set up the fuel lines. I actually had to pull the tank to put my fresh air box back in. Was able to fish the phone out through the fuel pump hole but could not see the ground wire through it.
r_towle
Apr 30 2017, 05:04 PM
took 5 seconds
flmont
Apr 30 2017, 06:49 PM
r towle....Thanks...Iam just not that computor literiate
flmont
Apr 30 2017, 06:52 PM
Click to view attachment I dont know why this oil filter wont fit..!!
flmont
Apr 30 2017, 06:53 PM
it hits the small car bracket and wont line up ??
flmont
Apr 30 2017, 06:54 PM
before pic
flmont
Apr 30 2017, 10:27 PM
Also, this is way to far forward even tho my 901 trans lines up with the factory trans mount.???
flmont
Apr 30 2017, 10:29 PM
I thought it would be very close to the cross member not beyond it
flmont
Apr 30 2017, 10:31 PM
these tranny mounts line up..
914forme
May 1 2017, 05:59 PM
Your on the right path, the idea with the small car is that you will need to cut the mount and mount it over an early style bar. I think I have detailed shots of mine in my build thread.
I made two of them
flmont
May 1 2017, 06:25 PM
And I suppose that's why the oil filter wont screw on either,..I will ck that out,.I thought it was to short ,..not to long but I do fell better,I would still love a cradle..lol
914forme
May 1 2017, 06:28 PM
flmont
May 1 2017, 06:50 PM
Well I was hoping to just bolt it in and be done,..But I can see now that's not the case ..
flmont
May 1 2017, 08:51 PM
BUT,..My oil filter will not screw on either is that the result of the brackets being to long ??
flmont
Jun 17 2017, 12:48 PM
I'am about to start my intake flip,I will be using the subie chip to eliminate the EGR system,and I will be using the spacer kit from X35 design.
1. I DON'T know how much of the EGR system to remove.( i dont have the chip yet )
2. I don't know how to do the ALT bracket
3. Is there a shorter crank pulley I can install on the 3.3..???
4. Thanks to all that can help...!!!! Frank
flmont
Jun 17 2017, 02:30 PM
Is this tiny bracket a safe lift point ,.I need to get engine on the engine stand
914forme
Jun 17 2017, 07:11 PM
yes it works fine.
flmont
Jun 17 2017, 08:29 PM
WOW,..I would have never thought it could handle the weight,..Thank U,..!!
Any thought on my previous post about removing the EGR system..??
914forme
Jun 19 2017, 07:58 PM
You use the rear hook spot, and I use a bolt up front to balance it all out.
You just block the EGR, with a steel plate, and a plug in the manifold if your using the stock exhaust manifolds. Since I did not keep the stock ECU, it might kick codes. Not sure
flmont
Jun 19 2017, 10:23 PM
yes,.Iam using the stk manifolds,..and the stock ECU,..But I will be chipping the ECU to stop those codes,.
jimkelly
Jun 24 2017, 05:35 PM
are you using 914 trans?
flmont
Jun 24 2017, 05:50 PM
Yes,..On the trans,..jim
flmont
Jul 3 2017, 08:39 AM
Are there any companies that make original color dye's for Porsche interior color's,Plus I cant get rid of the stains on this horn pad,.any Suggestion's
flmont
Jul 4 2017, 11:54 AM
Trying to do the intake flip, not sure what stays and what goes
Click to view attachment I am guessing that U open the harness,.( more slack from harness)to reconnect ,connector's,..and then buy new generic hose to then refit them as needed,..Am I any where near correct ?? Thanks Frank
BIGKAT_83
Jul 5 2017, 10:40 AM
Go to a auto paint store and get a couple of cans of SEM interior spray. They should have it in almost any color. These were black and have held up good for the last 15yrs.
Chris H.
Jul 5 2017, 11:08 AM
QUOTE(flmont @ Jul 4 2017, 12:54 PM)
You need to look at ThePaintedMans thread. He did a great job of explaining what he did.
flmont
Jul 5 2017, 12:15 PM
Yea, I could not remember his name/
write up from my home computer, Thanks !!!!
AZ914
Jul 5 2017, 04:20 PM
Regarding the steering wheel, you can hit that with some SEM dye too (like the seats).
flmont
Jul 5 2017, 06:01 PM
Thanks for the Dye tips,..Bigkat and AZ914 I will do just that,.!!! WOW 15 yrs that's great,..
flmont
Aug 28 2017, 09:34 PM
would it be safe to mount the Subaru ECU, next the the battery just like the original ECU or should I mount inside the cabin,..I didn't really want to drill a 2 in whole in the fire wall if I didn't need to ?? Thanks ,..Frank
Chris914n6
Aug 28 2017, 10:34 PM
QUOTE(flmont @ Aug 28 2017, 08:34 PM)
My ecu isn't water tight so I ran it to the trunk thru the targa latch cup and sealed that. Also provides plenty of space for a relay/fuse panel.
flmont
Aug 28 2017, 10:41 PM
yea,..I kinda wanted to hide it a little better if possible,it's better than under the seat that's for sure !!
914forme
Aug 29 2017, 07:47 AM
Subaru ECUs are mounted inside the cabin, not water tight. Drop it in the trunk, easiest. Or extend the harness and move it to the cabin.
Chris H.
Aug 29 2017, 11:58 AM
I'd put it in the trunk. You need a little protection but no need for it to be sealed water tight. If you extend the wires you have to use high quality stranded shielded wire for many of them. It makes for a very fat harness to pass through the firewall. The shielded wires for the cam and crank sensors are very sensitive. Any significant signal leakage will cause it to run poorly.
mgp4591
Aug 29 2017, 01:30 PM
I'd think the harness is long enough to put in the cabin, possibly between the seats either on the floor or the back. Easy enough to cover with a shield and some sort of material or pad. That's what I'm planning...
flmont
Aug 29 2017, 07:59 PM
Yea,..I don't really want to pull the interior out,.I will be working on it this weekend,..and I hope its not to hot,if I had 40 straight hours and cooler temps I could be very close to turning the key,barring complications of course
flmont
Aug 29 2017, 08:04 PM
Chris914n6,...why do I need the fuse panel,.Iwas expecting to wire it thru my chassis harness and use my existing fuse panel...??
Chris914n6
Aug 29 2017, 11:19 PM
QUOTE(flmont @ Aug 29 2017, 07:04 PM)
My Nissan will be a little different, but there will still be more fuses & relays involved.
8 relays total. ecu, ign, fuel pump, starter, ac comp, cruise, fan 1 & 2.
14 new fuses: ecu hot, ecu switched, coils, injectors, fuel pump, fans, etc...
This is beyond the chassis fuses & relays. This panel replaces the stock panel in the engine bay.
This is why I don't have a build thread, can't find a finished pic
mgp4591
Aug 30 2017, 04:43 AM
40 plus yr. old wiring with those crappy fuses and no room for relays? Nope... not for me. Play with the wiring lengths that you have, see where you can go, and fit it as safely as you can. If you need to have it in an exposed area, install it in a box where it can be accessed quickly and that's fairly waterproof. Preferably up high would be best.
76-914
Aug 30 2017, 08:28 AM
Listen to these 2 guys. There both mechanics. You can't have too many fuses or grounds or relays. My Dakota Fan Controller instructions were quick to point out that the relays (switched & hot) could not share the same circuit or bouncing was likely. I experienced this once when I designed my own neutral safety switch. The computer went wild and so did the idle circuit. I didn't know why then but now I understand. This is what happens when a plumber ventures into the electrical world.
flmont
Sep 9 2017, 07:13 PM
what is the best/easy way to pull the clutch assy. I am thinking about changing out that plastic panel that is on the back of this engine case to the metal one,.?? Thanks Frank
