QUOTE(SirAndy @ Sep 27 2016, 07:02 PM)
It won't give you "a few ponies" but it will most certainly give you a headache.
These engines aren't starved of fresh air. Without modifying the rest of the engine, adding more intake air will do next to nothing for performance.
Now, if you were thinking about adding a good 4-1 exhaust header, that would actually do something for your HP.
I'm pretty sure it doesn't have the stock exhaust, sort of looks like one of those Burch systems, but not completely sure. Again, don't know a whole lot about these cars. In what way would removing those two hoses and capping the fittings with breather filters give me a headache? Will it stumble and bumble because those hoses aren't attached and routed to the airbox?
My other current project car is a 1991 Mercury Capri turbo, which is an absolute hoot to drive, very zippy for being 25 years old and only having 53K miles. I put on a 2.25" exhaust with a free-flow cat, resonator, and dual tip; swapped in a set of Audi TT leather seats; replaced the rear sway bar bushings, brake rotors, and pads; etc. Going to leave the intake alone though, because of how the airbox and MAF sensor is set up. Have a 15x6.5 set of wheels and 205/50 tires in mind for it, along with painting the bumpers black and that should just about do it on that car (it has a new convertible top, and a new headliner in the removable hardtop). My other project, which is more or less done, is a 2000 GMC Sonoma with an LT4 and T56 trans. Bought it with the conversion already done, with the correct wiring harness and computer, one-piece aluminum driveshaft, limited slip rear end, coil overs on the front, cal-tracs on the back with lowering blocks, etc. I changed the wheels and tires, swapped in a set of Cobalt SS Recaro seats, and replaced the mufflers with a pair of Summit chambered ovals. Only thing I did in the engine compartment was replace the cone filter with a dual-stage Uni foam filter.
So you can see with these other projects, I'm finding it a real challenge to not molest this 914, and to leave it pretty much stock. I was thinking of replacing the seats with something more adjustable, but that thought passed, lol! Maybe I'll concentrate on more functional things, like s/s braided brake lines, and getting the darn stereo system to work...that's it, this will be the completely stock, unmolested car!
