re: my LED posting, I figured out some time ago that idle problems on my D-Jet car when the lights were on were due to parasitic drag from the alternator. My question is: what's wrong with the stock alternator?
First off, source material. Pretty much everything I know about the charging system on our cars and how it works comes from this link on Richard Atwell's page:
http://www.ratwell.com/technical/ChargingSystem.html
The 914 stock alternator is rated at a maximum of 50 A at 2200 rpm. Like on other VW's, the alternator pulley is half the size of the engine pulley, so if you have the idle set to 950 rpm, and the voltage regulator is running at 80% duty cycle (maximum sustained duty cycle Atwell recommends), then at idle, the alternator should be able to supply 950 * 2 / 2200 * 50 * 0.8 = 34.5 A.
In my posting about the LED lights, I calculated that with the lights on, and using low beams, the stock incandescent lights pull 19.5 A. Additionally, the car needs current to run the ignition, the fuel pump, and to drive the ECU. I'm not sure of how much of a load this is, so I'm going to just take a stab at it and say 100 W, so at 12.8 V this would be about 8 A, for a total of 30.8 A. That would imply a duty cycle at idle of 71%, which isn't that bad, and leaves 9% to drive other accessories such as the heater and fresh air blower, radio, and wipers. Yet from my experience, even at this duty cycle, the drag from the alternator is enough to pull the idle down to as low as 500 rpm, making the problem even worse. I've looked at the voltage on the field coil of my alternator at idle with the lights on, and it looks closer to 100% duty cycle to me, not 71%, and that was after opening the air bleed screw to get the idle back up to 950 rpm.
In my case, by going to LED's and reducing the required current for lighting at idle from 19.5 A down to 5.0 A, the idle is almost unaffected by turning on the lights. For my car, clearly the parasitic drag of the stock setup is a problem.
Is my math and reasoning right here? For people who have installed 70 A and 160 A alternators, have you seen improved idle stability? Are some of you running D-Jet setups with the stock alternator and stock lighting, and have only 50 rpm or less idle drop when turning on the lights when the car is idling at 950 rpm?
