QUOTE(euro911 @ Sep 29 2016, 02:56 PM)
Mike, drop the port end of the AAR into a small soup can (or similar vessel) and pour in enough solvent to fill the ports. Let it soak for a day or two, then apply a 12v power source to see if you can get the plunger moving. Repeat the process a few times and it should be good to go. The cleaner you can get it, the better.
Hmm. Where have I read this recently?
Good luck! I'm still working on mine. Results still inconclusive at this point.
