bdstone914
Sep 29 2016, 12:43 PM
Three sets still available still.
I have several pairs of these made after seeing that most of them are badly bent from dropping the trans down without loosening the bolts in the engine bar brackets.
They are made to the same dimensions with a slotted center hole. Made from mild steel and powder coated satin black.
$30 a pair shipped.
74ravenna
Sep 29 2016, 01:25 PM
I'll take a pair.
PM Sent
bdstone914
Sep 30 2016, 07:41 AM
Three sets sold, thre sets still available.
Jett
Sep 30 2016, 08:29 AM
I'll take a set as well please.
PM sent
michael7810
Sep 30 2016, 11:26 AM
Where exactly do these go? My car is a 72 with side shift conversion and I'm sure it does not have these. Thanks
marksteinhilber
Sep 30 2016, 11:42 AM
QUOTE(michael7810 @ Sep 30 2016, 10:26 AM)
I'd like a pair Bruce!
bdstone914
Sep 30 2016, 11:57 AM
How does the engine bar mount to the body? I have seen conversions done wrong using the original tail shift mounts and then cut down the engine bar ends.
They bolt to the engine mount console. The ends of the bar bolt to the center hole in the bracket.
michael7810
Sep 30 2016, 02:27 PM
OK. Duh. I have them, I never paid attention to what the bar bolts to.
Thanks
914bub
Sep 30 2016, 05:17 PM
QUOTE(michael7810 @ Sep 30 2016, 01:27 PM)
Thanks
Bruce
Are these the only brackets that differ from a tail shift engine mount bar? in other words I have a side. shift engine mount bar but not the brackets that go at the ends. For some reason I thought the ones I needed were like a square, steel "box". If these are the ones I need ill take a pair.
bdstone914
Sep 30 2016, 05:27 PM
Bruce
[/quote]
You also need the engine to rubber mount brackets. The tail shift uses a one piece bracket and side shift uses two brackets.
A little hard to see but the orher brackets are in the picture near the center rubber mounts.
bdstone914
Nov 9 2016, 09:05 PM
Bump
bdstone914
Nov 25 2016, 10:27 PM
QUOTE(bdstone914 @ Nov 9 2016, 09:05 PM)
Bump
bump
