The challenge is on. I do need to fix this as it is annoying. Thought that the Guru's of 914 World would be able to help. Are there any out there ?? Help Please !!!!!
I find after putting in the interior finishing up the car that the Seat Belt Warning light is illuminated all the time when the car is in the run position. Worse yet when a turn signal is used, either right or left, this warning light also flashes. Some background is in order to explain
All lights and turn signals work correctly with the key either in the accessory or run position. Dash lights work as expected from what I can tell running in the day time.
No fuse issues
The Seat Belt Warning system was by-passed. Both Yellow wires connected together.
No seat belt wiring to either the seats or the belts is active.
Wore out the wiring diagram looking for a possible solution to no avail. Find no cross over to these systems anywhere
I could just remove the bulb but surely something is amiss and I'd like to fix it.
Help Please !!!!
