Hi all, working on the vacuumhoses check to see what needs to be replaced.
Most are not real Vacuumhose to start with, so I should replace them anyway.
I have a question about a part in the vacuumhoses spaghetti
It is a 1.7 1973
Question is about the marked splitter:
to give you an idea where it is located:
This part looks homemade to me and I am not sure if it should be there.
If I check on
http://www.pelicanparts.com/914/technical_...4_17FI_diag.htm
I do not see any hose split in two or three......
Question : what should be there ?
Thanks for your help.
