My 2.2T motor ran fine on first startup,about 25mins running and no issues save a few small oil leaks that were easily sorted.
Now I have an issue with oil pressure....after about a minute or 2 of running the oil light comes on and stays under rpm increases,there is no knocking and rattling to indicate lack of oil however.
I must add that the oil light doesn't come on when the key is on ,I find that odd
My oil gauge is reading pressure but is a not in great shape,it isn't reading in the right range but responds to rpm increase,my intention is to install a spare 52mm VDO one I have to see what the real pressure is.
Thinking of possible causes;
blocked oil filter...considering engine is used as well as oil tank,
oil pressure relief stuck,
blocked oil pump pickup/strainer,
Perry mentioned the oil filter console could be fitted wrong,
Wise words and advise would be most welcome,I don't intend running it anymore till I have something sorted
PS I'am running the right oil for the motor .
