QUOTE(Krieger @ Sep 30 2016, 10:52 PM)
You probably know but you are also missing the nut for the pin that holds the strut to the ballpoint.
And the taper pin is not in all the way. Might be in crooked. Remove, grease and reinsert. Use a nyloc nut and god flat washer.
Either go with S aluminum calipers or early A calipers that use the 7mm spacer and use the 20mm thick 911 rotors for the 69-78 ? 911.
Later SC calipers take the 24mm rotors which are not needed on a 914 and add to the unsprung weight.
