UPDATE!!!!!
the dyno is cool...however...make sure that you have someone who knows what he is doing....
I guess that this guy is used to doing drag cars etc....when I said that I wanted to hold certin rpm's and load all I got was a blank stare....
anyway, my afr is all over the place...I finaly got it rich enough to give a half way decent pull. got 134 hp and 165 ft lbs.
the printer ran out of ink, so no pictures....I was way rich at full throttle and lean at low rpm's. I know what I have to do now.
The key is getting a smooth VE map. I had a lot of peaks and valleys.
I still need further work on this as there is still a lot more HP there.
by the way, what symptoms do a broken motor mount make??? when I was doing burn outs I started to get a lot of wheel hop and the shifter started to move in strange ways?? if I was easy on the clutch and gas, I could start ok from a stop light and the rest of the gears were ok. hard launch or punch in 2nd, and strange stuff...CV bolts are safety wired and OK.
Clutch is a solid kennedy unit.
