QUOTE(aircooledtechguy @ Oct 13 2016, 02:07 PM)
I was not clear in my response; sorry. The above response was actually meant for those who have yet to purchase an ECU. You can order it from wherever you buy it with the features you want so there's no need to mod it yourself.
So basically you're saying you are hijacking the OP's thread.
The OP has already bought his system and you are coming damn close to saying he's an idiot for not buying a MS3 and off of your buddy.
I don't give anyone any crap about pimping your services. Should I be??
As far as anyone recommending Mark. I never hear it over and over again in the same thread. You hear it once and the odd time a single person might concur...but that's it.
This thread has several direct "you need to buy from this guy", twice from you and both of those times after Mike had already bought his system from DIY Autotune. It also has a few more what I'll call indirect references.
Yes not all from you and you can't control what others say, but damn it gets annoying.
The main advantage to MS3 is the resolution in tuning over any of the previous versions. Everything is pretty much built in already so the user just uses what they want and not what they don't.
MS3 for a 2056 is likely more than what most would need, however how many people stay with a 2056 over the life of their cars?? Many people I know tend to want to step up to a larger motor later on. That's where a system capable of more things like sequential fuel & spark become rather important. I run my system on a small street motor and on my race motor. Yes I don't need sequential fuel & spark on a 2056 with the cam that has, but it is important on the other motor I run in this car with the exact same system.
So what?
I'm running my 2.6L T4 nickies engine on my 13 year old SDS....
oh my god! It's batch fired!Sure it has the latest V16 chip...but batch fired! The horror!
My bug runs smooth as silk, pretty solid AFR readings, the wife even drives it. She gets good gas milage..I don't.
I've built two 930 engines that run on SDS, one engine and trans is north of $60K and makes 550hp dynoed...and it's batch fired? OMG the ignition is batch fired too!!!!!
Oh the huge manatee!! the dyno must be wrong!!!! It's NOT sequential!!!!!It's a fucking electronic carburetor and distributor.... not a futuristic fembot with full "sequential" auto suck capabilities.
Sorry Mike, hopefully we can now get this back on track for your project.
