falcor75
Oct 3 2016, 11:22 PM
This weekend I fit the new version of the front trunk seal from 914 Rubber.
Great improvment over the old version. The old one I got was much too long across
the width of the car and wouldnt fit right. The moulded corners are great.
I forgot to snap some pictures but I'll try to get some up after work today.
Thanks Mark & Co for doing what you do!
falcor75
Oct 4 2016, 12:46 PM
walterolin
Oct 4 2016, 02:26 PM
Looks good. Did you use glue? I have a new one to put in.
TheCabinetmaker
Oct 4 2016, 02:29 PM
That looks very nice. Any issues with trunk lid closure and or fit?
mmascari
Oct 4 2016, 02:31 PM
What kind of glue do you use for this? I also need to install mine.
I have a new one also. I just placed it in the trough but did not glue it down so I can lift it to get any water out if I get caught in the rain.
sb914
Oct 4 2016, 02:59 PM
Can you see the seal with the truck closed ?any pics with trunk closed ?
Thanks Eddy
Mikey914
Oct 4 2016, 04:51 PM
Thanks for the props Mats.
76-914
Oct 4 2016, 05:20 PM
No glue needed. Fits tighter than Socks on a Rooster. In fact you need to massage it in place. One of Marks best products yet.
falcor75
Oct 4 2016, 10:21 PM
QUOTE(76-914 @ Oct 5 2016, 01:20 AM)
No glue needed. I'll take a pic with the hood closed later but since I'm using a glassfibre hood it might not be the best fit compared to a steel hood.
falcor75
Oct 4 2016, 11:54 PM
Pictures with the hood closed. The seal looks normal as far as I can tell.
Click to view attachmentClick to view attachment
jkb944t
Oct 5 2016, 06:12 AM
I have a new seal too and it is a huge improvement over the original seal. I just pushed it into the seal channel and it fit great but I did glue it down in each of the corners with some 3M trim adhesive just to be sure it stayed in place.
The trunk lid closes beautifully with this new high quality seal. I highly recommend it to anyone that needs a front trunk seal.
Jeff B
Mikey914
Oct 5 2016, 07:49 PM
Thanks for the feedback guys. I wasn't making these for years and was having to source from the one game in town that was, and doing so inexpensively. I was buying them for about 1/2 of what these sell for but finally decided to bite the bullet and do it right. These don't sell as fast (they are about $20 more), but the difference is night and day.
So it's nice to see when others can appreciate the effort.
maddin
Nov 6 2016, 12:25 AM
Just fitted the old version that came with the big rubber kit...doesn't fit well at all...I don't think it's much use really.
Might have to order the new version
era vulgaris
Nov 6 2016, 08:52 AM
QUOTE(jkb944t @ Oct 5 2016, 08:12 AM)
You should NEVER use any glue for the front trunk seal. It prevents water from moving through the channel, and that's how your front trunk gutter will eventually rust through.
914rubber's new front trunk seal fits so well, there's no reason to glue it. Ever.
Jett
Nov 6 2016, 10:13 AM
Mark, does 914 Rubber now only sell the new and improved front trunk seal? Is the rear trunk seal also newly designed?
I want to purchase the new versions but want to make sure we don't end up with the older style.
Thanks
QUOTE(Mikey914 @ Oct 5 2016, 06:49 PM)
Mikey914
Nov 6 2016, 12:05 PM
I now sell only the new front trunk seal. The upper bulkhead you have the option of the OEM or the larger seal.
