surfdogskier
Oct 4 2016, 01:25 PM
I have no idea what this is or does. I can't find anything on it. It is a turning switch with a wire attached to it. I havent tore my dash apart yet to figure out where it goes. It is a turn style switch. I wondered if it was some type of kill switch since I can't start my car for the life of me. Do any of you have this or is this stock?
db9146
Oct 4 2016, 01:32 PM
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000".
Oct 4 2016, 02:09 PM
QUOTE(db9146 @ Oct 4 2016, 12:32 PM)
PanelBilly
Oct 4 2016, 02:13 PM
Turns the rust preventative system off. Once this has been activated the car begins to fall apart.
TheCabinetmaker
Oct 4 2016, 02:24 PM
Ejection seat switch
Catorse
Oct 4 2016, 02:25 PM
Muffler bearing oiling port
Frankvw
Oct 4 2016, 02:31 PM
On a serious note: do NOT turn it while driving....
surfdogskier
Oct 4 2016, 02:55 PM
QUOTE(The Cabinetmaker @ Oct 4 2016, 04:24 PM)
Is there any way I can switch it to the passenger side?....I could use it on a few people I know....
surfdogskier
Oct 4 2016, 02:58 PM
Thanks guys for the input!...
rfinegan
Oct 4 2016, 03:27 PM
Agreed ....
QUOTE(Frankvw @ Oct 4 2016, 12:31 PM)
TheCabinetmaker
Oct 4 2016, 03:38 PM
QUOTE(surfdogskier @ Oct 4 2016, 03:55 PM)
Yes. Just switch the wires around.
BillC
Oct 4 2016, 04:53 PM
It looks like it might be missing the knob that goes on the shaft. It'll be harder to turn without the knob. IIRC, the knob is held on with a set screw, which probably came loose and let the knob fall off.
Rand
Oct 4 2016, 05:03 PM
QUOTE(The Cabinetmaker @ Oct 4 2016, 02:38 PM)
I won't crack a joke about the knob being in the drivers seat. Love this group.
theleschyouknow
Oct 4 2016, 06:13 PM
I heard or read this somewhere recently (probably on here) but I liked it
always check the nut holding the wheel first
cjl
Alfieg23
Oct 5 2016, 02:22 PM
Is this reset knob accessible if my car has the A/C vents running along the bottom of the dash? I can't seem to locate it.
QUOTE(theleschyouknow @ Oct 4 2016, 08:13 PM)
cjl
malcolm2
Oct 5 2016, 02:38 PM
QUOTE(db9146 @ Oct 4 2016, 02:32 PM)
"000
0" if you are lucky..... mine stops on 001
0 every damn time. drives me crazy. And mine is not attached to the btm of the dash.
Some PO pulled it out and re-installed the nut (that rusted) so mine just dangles, never to be attached again.
malcolm2
Oct 5 2016, 02:40 PM
hey, where are you in East TN. Good to see another Tennessean on the board.
I am in Mount Juliet.
Frankvw
Oct 5 2016, 03:44 PM
"Is this reset knob accessible if my car has the A/C vents running along the bottom of the dash? "
YES. I have that and it is there....
TheCabinetmaker
Oct 5 2016, 04:55 PM
QUOTE(malcolm2 @ Oct 5 2016, 03:38 PM)
"000
Just pull it out of the back of the Speedo can. Its just poked in a hole. Unrust it, and stick it back in.
poorsche914
Oct 5 2016, 06:33 PM
QUOTE(malcolm2 @ Oct 5 2016, 04:40 PM)
He's in my neck of the woods... Sevierville.
Trying to find time to go over and help him get things straightened out.
malcolm2
Oct 5 2016, 07:05 PM
QUOTE(The Cabinetmaker @ Oct 5 2016, 05:55 PM)
"000
I tried the unrust process, but it didn't work. So I either get a new cord or live with it. I think the 1 mile starting point comes from the odometer not the cord.
