Hey fellas:
OK, so things are moving along on the clutch replacement project (although slowly).
I was starting to remove the rear seal that's behind the flywheel and I took my new one and held it up against the old one (which is still installed) and it seems quite a bit too big in diameter.
Here's the P/Ns on the box:
029-105-245B
81-25946-10 VW
75x95x10/9,5 A LD FPM/ACM
Can anyone tell me if I have the wrong seal? If I do have the wrong one, can you tell me what the right P/N should be? I ordered this seal with the PP clutch kit. Has anyone else noticed this or had this problem too?
Any help is greatly appreciated.
Thanks!
Andy...
