QUOTE(The Cabinetmaker @ Oct 9 2016, 11:44 AM)
Catsltd, was the machinist also the engine builder? I can't see how improperly honed cylinders would cause oil leaks. I've had dozens of cylinders either honed or bored by machinist. Only two cylinders were ever rejected and they were rejected by the machinist. Unless you have lots of experience honing cylinders by hand, I don't recommend it as a diy project
The work the shop did for me was to fix oil leaks,adjust timing etc.
$1500:00 dollars later,timing was so far off it was running hot all the time,and on the way home my car ran out of oil.
I am scared to death about going to a shop that I know nothing about and letting them mess up my cylinders.
I have 95 PSI on hot motor for compression,with a few drops of oil it goes to 150 pSI.
The motor sat for 15 years,so I am sure I need at least rings,but I am Not going to get cylinders honed,dont need the worry.
I read going to 96MM is fine with Ljet,also the 1.8 heads have big enuff valves etc,for the 96MM pistons,no machine work needed.
