buck toenges
Oct 9 2016, 03:35 PM
I have my engine out of car. I need to remove the engine support and heat exchangers off motor to put on another engine. Is there an easy way to do this?
Thanks,
Buck
iankarr
Oct 9 2016, 04:43 PM
What is the engine resting on now? If it's on a stand, it's pretty straightforward. The tricky part is getting the exhaust bolts off. A thin walled 1/4" drive socket usually does the trick. Careful that you don't break off the studs. Penetrating oil helps get things going.
bdstone914
Oct 9 2016, 07:43 PM
Get it on an engine stand or at least a foot off the ground. 1/4 inch drive 12 or 13mm socket and 6 inch extension are needed for one of the nuts . The rest are not too hard to get to.
injunmort
Oct 9 2016, 09:13 PM
how did you drop the engine? with a jack, furniture dolly, engine crane, or is it just sitting on the floor? a little more info would help. because without it, i would use sockets and open end wrenches.
r_towle
Oct 9 2016, 09:32 PM
Milk crate
