QUOTE(tornik550 @ Oct 10 2016, 04:03 AM)
So if I choose not to use the vacuum advance- can I just leave the vacuum hose off or is there anything else I need to do to not use the vacuum advance?
Several ways to go about it. The easiest is to just leave it unplugged.
The best-functioning way is to get a replacement distributor that is set up for your particular application. The original distributor is set up with a curve that assumes vacuum retard (and possibly vacuum advance) plus a low-compression engine with a mild cam running fuel injection. Your engine violates pretty much all of those assumptions.
Plus the original distributor is 40+ years old, and will have some wear. A new distributor shouldn't have any wear.
I bet the guys at the Type4 Store would be happy to sell you a distributor. Others likely would as well.
--DD
