QUOTE(Dave_Darling @ Oct 10 2016, 03:49 PM)
QUOTE(socal1200r @ Oct 10 2016, 03:11 PM)
Just get rid of the FI crap and go to tried and true carbs...
OUCH! I just rolled my eyes so hard I hurt myself!
The FI vs. carbs discussion should go in its own thread. In fact, you can do a search and find about twenty different ones through the years, and add your two cents on to that.
This thread is about fitting a modern FI system onto a 914.
Yes, it can absolutely be done. Some will require you to fabricate parts, some will require a lot of creative adaptation of parts, most will require some electrical work and re-wiring. It is very unlikely that any will be completely right when you bolt them up, but there's at least a half-decent chance they will be as close to right as the original FI was, once you fiddle with things a bit.
That said, you get a whole lot more flexibility if you use something like Microsquirt to control a bunch of modern components. You don't have to live with anything that was designed for a different car, because you can tweak pretty much everything.
Of course, that means that you can tweak everything incorrectly as well. Probably more easily than making it all correct, since there are a lot more ways to be wrong than right. But it's a good learning experience, so...
--DD
Another thing to make clear is that for the unmodified 1.7 and 2.0 L motors, with stock pistons, valves, cam, etc., that to my knowledge, nobody who has fitted carbs or an aftermarket FI system has achieved better performance (i.e. improved torque or power).
As far as driveability is concerned, carbs will always be worse because they simply don't have the capability to react to all of the various engine conditions encountered in normal driving. It's possible that an aftermarket FI system could achieve better driveability than D-Jetronic, though such systems as active idle speed control and multipoint engine temperature measurement, improved load metering, etc., but that depends on the system implemented.
As far as emissions go, carbs are again the worst solution, as most carb systems can't handle fuel tank or crankcase emissions, and the poor atomization at low venturi speeds leads to high CO emissions. Aftermarket FI systems with lambda control can reduce emissions as compared to D-Jetronic.
One thing that's often thrown out there is cost, with the claim that going to carbs is cheaper than fixing the D-Jet system. With rebuild kits available for the TPS and the MPS, as well as the classifieds here, a D-Jet system can be fixed up relatively cheaply. New carbs, especially twin IDF's, aren't cheap. And if you do save some money, you'll probably lose more in the resale value of your car, because carb cars sell for less and can be difficult to impossible to pass emissions in some states.
