That's a drivers side (left) 911 rear M-Caliper. 1969-1983
This caliper came with the new LWB cars and their new trailing arms. D31 Pad size. 38mm pistons. These had contoured flat top pistons, similar to 914 front calipers with the 20 degree angle cut in the piston top. These calipers all had knockback pins and mechanisms until 1976 when the pistons changed to a cup style (which is what this probably is based upon the casting numbers):
1969 - No spacers on standard 911's with solid rotors. 10mm spacers (not 11mm) on 911S models with 20mm (not 24mm) vented rotors.
1970 - All 911's moved to vented rotors. Spacers in these and the 69S cars were rounded and machined.
1973 - Spacers became molded, cast and then milled. They had a more precise fit (not that it matters, just more of an appearance issue).
1976 - When the cars moved to power assisted brakes, these calipers lost their knockback mechanisms and internal pins. The power circuitry kept a constant 2-3 PSI of residual pressure on the system. This is when the "cup" style pistons arrived on the scene. More surface area for cooling.
So, the same caliper lived on the rear of a 69 911T all the way through the 911RS and first 930's.
In 1984 the 911 became the 3.2 Carrera and it received a new caliper with larger 42mm pistons. This is the same time the 911 received it's first "Pressure Regulator" (not proportioning valve) like the 914 to prevent the larger rear pistons from locking up. This is when 14mm spacers were added to the rear calipers and the car received very heavy 24mm rotors.
What? TMI?
