QUOTE(pbanders @ Oct 16 2016, 02:34 PM)
The problem with removing the CHT is that it has an axial lead. You have to modify your 13 mm socket or extension so that the lead as a place to go. You can cut a slot up the side of the socket for the lead wire to sit in, or you can cut off the corner of the square end of your extension so that the wire fits in the gap between the corner and the socket hole. The CHT is secured with a copper washer that falls off easily when you're removing it or re-installing it. If it falls off during removal you'll have to fish it out, but you can prevent it from falling out on re-installation, by securing it to the CHT with a small drop of superglue, which will break off during tightening. When re-installing, be extremely careful to make sure the male spade connector on the wiring harness that's inside of the plastic insulating housing goes completely into the female spade connector that's attached to the CHT. It is very easy to think you have inserted it, when it's actually jammed between the plastic housing and the connector. This will lead to intermittent contact and poor running.
I should have said this first, but why are you removing it? It's easy enough to test it without removal. When cold (let the car sit overnight), disconnect the CHT from the wiring harness and use a DMM to measure the resistance to ground. Values are in the table in the link in my sig file, somewhere around 2.5 kohm. Reconnect the CHT then drive the car for 30 minutes, and repeat the test immediately after stopping. The resistance then should be on the order of 50 ohms. Anything different and the CHT is faulty.
Hi thanx for responding so quickly. I have tested chg and it is good. The problem was it was not connected. But thanx for your information. I will NOT touch it.
Question: which is the idle screw because I changed the broken AAR now I have a good one
And the idle is way too low. So I need to increase the idle a bit.
Thanx
