freezing14
Apr 19 2005, 12:26 PM
the car is finall drivable after a year of major surgery, got the car in 15-20 boxes,, it startes fine idle almost good accelerate ok but if I just floor it , it kind of hesitate bucking, but it still accelerate ok, what the hell is wrong, i have checked pretty much every single component I put on the car before installing it , any ideas?????
TheCabinetmaker
Apr 19 2005, 12:29 PM
FI or carb?
freezing14
Apr 19 2005, 12:31 PM
oops sorry,, 1.7 d'jet
Joe Bob
Apr 19 2005, 12:33 PM
Fuel pressure and filter check...
nebreitling
Apr 19 2005, 12:36 PM
check TPS alignment w/ multimeter.
TheCabinetmaker
Apr 19 2005, 12:38 PM
QUOTE (nebreitling @ Apr 19 2005, 01:36 PM) |
check TPS alignment w/ multimeter. |
Yep.
freezing14
Apr 19 2005, 12:41 PM
I know the fule pressure is 29 lbs and the fuel filter is nes and only 1 gallon of gas has gone trought it,, as for the TPS,, I taught that it needed adjusting at idle only ,, I did not know it needed or how to adjust at WOT ( wide open throttle) any info??
TheCabinetmaker
Apr 19 2005, 12:59 PM
freezing14
Apr 19 2005, 01:18 PM
cool thanks,,,
Dave_Darling
Apr 19 2005, 02:25 PM
QUOTE (freezing14 @ Apr 19 2005, 10:41 AM) |
I know the fule pressure is 29 lbs and the fuel filter is nes and only 1 gallon of gas has gone trought it, |
Is the pressure 29 PSI when the car is misbehaving?
New filters can get clogged quickly when there is a lot of sediment in the fuel tank. The sock filter over the inlet pipe can likewise get clogged quickly.
--DD
