QUOTE(porschetub @ Oct 17 2016, 01:14 AM)
QUOTE(Catorse @ Oct 17 2016, 05:10 PM)
All it needs are those three connections - 12v switched, ground, and tach signal. Your problem is that it doesn't have an adapter for an early car.
Try looking for a "tach adapt" which converts the tach signal to something your tach can understand.
But which pins do I connect to? otherwise your answer is well ....useless sorry ,already have tachadaptor in there and know I have to change the jumper connection for the early to late input rate.
I just did this on my car; I have a 2.7 with a 911 2.7 tach and electromotive ignition. I don't recall the exact pin out, but they were clearly marked on the back of the tach (engraved). I did not need to use all the pins, just like you. My tach works just fine, but having said that I had it rebuilt at No Ho speedo, and they asked me what kind of ignition I was using.
You can figure out ground and +12 volts.
My question to you is where your tach signal is coming from?
And, have you ruled out the tach itself as being free of problems?
Lastly, go find a 2.7 wiring diagram. It will tell you what each pin means.
