As I approach the first attempt at starting this thing, it struck me that I ought to do my best to channel Steely Dan:
Countdown to Ecstasy!
Boring photo but this is the "buttoned up enough to run" frunk:
- radiator hose pass through panel temporarily pop riveted (can't final rivet it until the car is painted)
- fan relays wired and tested
- radiator hard lines fully installed
- radiator shroud in place
- brake/clutch reservoirs ready for fluids
For those wondering, "what's up with that plain radiator shroud?", I have yet to source/layup the carbon fiber inserts for the stamped shroud and beyond that, it'll need to be painted ahead of bonding in the inserts.
So, because I'm focused on doing only what's needed to get it running and driving, and I have to have some sort of shroud, I cut this aluminum version. Virtually no style points, only what's needed.
@Rand , aren't you proud of me?
