Bravo.
Consider closing the space/gap on the plate in front of the first vane. Then either lower the subsequent units (3/8" or so) or increase the height of the first, likewise. I cannot tell from your pictures but they all appear to be similar in height and there is an opening in front of the first vane (maybe not, though).
I doubt you will want to do this from an aesthetic position but also consider increasing the angle (>vertically) of the first unit or alternatively add a slight radius (up) to the top of it (swell). This would create the low pressure zone needed to exhaust the frunk with greater efficiency.
You can explain all of these oddities to those "at car shows or WCR" as an actual "functional" design; not just a design.
