tygaboy
Oct 21 2017, 09:12 PM
Driver side front suspension bar.
tygaboy
Oct 21 2017, 09:13 PM
Another door bar vertical.
tygaboy
Oct 21 2017, 09:14 PM
Artsy-fartsy shot of the day.
Morph914
Oct 21 2017, 09:32 PM
QUOTE(bbrock @ Oct 21 2017, 03:44 PM)
Second that!
tygaboy
Oct 22 2017, 10:09 AM
You are all too kind and I appreciate all the encouraging words.
tygaboy
Oct 22 2017, 10:15 AM
Back to the seat belt retractor mounts. I decided to reshape the lower section of the braces to close off any opening into the brace and to make it easier to get it fully welded to the lower cross bar.
The mods are all done and both braces are tacked in.
tygaboy
Oct 22 2017, 04:40 PM
I got the passenger side sway bar reinforcement plate all welded in. Still need to dress the welds. It'll get seam sealed after primer is sprayed.
That was a long weekend of fabrication and welding. I feel like a lot got done.
And yet so much remains to be designed and built.
A friend of mine says "You should get a white board and write down everything that you need to do..."
I think if I did that, and faced the reality of what's ahead, it would scare the crap out of me and I'd stop the build.
So I'll end this weekend with this pic and a comment:
Sometimes you just have to step back and look at the big picture.
Man, I'm loving how this car is shaping up...
BIGKAT_83
Oct 22 2017, 05:43 PM
QUOTE(tygaboy @ Oct 22 2017, 06:40 PM)
Me Too....
914forme
Oct 23 2017, 05:36 AM
Get it done so you can
Inguiring minds need to know, how much fill rod / Mig Wire, and how many bottles of Argon Argon/CO2 have you burned thru?
Only reason I ask is people seem to think I spend to much time with my
mb911
Oct 23 2017, 05:52 AM
QUOTE(914forme @ Oct 23 2017, 03:36 AM)
Thats a great question.. I just did a count on my project.. I have went through 2 11lb spools and 4 tanks so far.. Onto the 3rd spool now.. Problem is allot just gets ground off.
Chris you may have more then I at this point?
914forme
Oct 23 2017, 07:09 AM
I on my third 11 pound spool also, just upgraded my tank, I had an 80, burned thru 4 of them. I am now on my first 150 Argon / Co2 for the Mig. TIG I have gone through a 3 sleeves of filler rod, and several tungstens, most damaged due to improper / learning to sharpen tungstens. And on my first 180 tank of Argon.
mb911
Oct 23 2017, 07:21 AM
Worst part is I have a leak on my argon co2 line that had gone undetected for a bit.. Now all is good.. I am almost all done welding though on my project.
Chris probably has more welding to do then I
bbrock
Oct 23 2017, 07:47 AM
I'll be picking up my third 80 bottle of C25 today and that will easily get me to the finish line. And I think I'll make it through with only one 11 lb. spool of .023 plus a little easy grind for the body sheets. Would have been even less if I were a better welder. But I'm not building my car from scratch like you guys.
mb911
Oct 23 2017, 08:22 AM
I am running .030 so less wire per spool for me..
tygaboy
Oct 23 2017, 08:44 AM
I have no idea how much wire/gas I've used on the car since I also use the same welding rig for all the work I do as part of my little side business: Red Barn Yard Art.
So it got used for all the WCR items, the Porsche crests, etc.
I have gotten better at paying attention to supplies so I always have a spare bottle and 10lb spool for the MIG. I use .023 for when I'm doing sheet metal and .030 for the structural work.
The TIG rig has one of those giant bottles so I just have to keep an eye on that.
Rand
Oct 23 2017, 09:08 AM
Cringe. Good welds don't need to be ground. I love a beautiful fish scale.
bbrock
Oct 23 2017, 10:43 AM
QUOTE(Rand @ Oct 23 2017, 09:08 AM)
I think he's talking mostly about butt welding sheet metal for seamless patches.
mb911
Oct 23 2017, 11:16 AM
But what do I know only taught high level welding for the last 20 years
Click to view attachment These are headers I just finished up.. No grinding on this
Rand
Oct 23 2017, 11:53 AM
Gotcha. Totally get it on the butt welds. Beautiful headers! Huge respect to the great welders.
The grinding comment just brought up the image of the "eagle crap" welds I've seen.
mb911
Oct 23 2017, 12:01 PM
QUOTE(Rand @ Oct 23 2017, 09:53 AM)
I hear that.. Grinding outside of restorations is typically just for fixing mistakes.. I often tell my students (average age is 32) its not grinding class..
bbrock
Oct 23 2017, 03:03 PM
QUOTE(Rand @ Oct 23 2017, 11:53 AM)
tygaboy
Oct 26 2017, 05:12 PM
914 Rubber's GT Headlight Kit arrived today!
tygaboy
Oct 26 2017, 05:29 PM
As usual, I'm all over the place. This evening, it was narrowing the flip rear trunk hinge. The Buick it came from is a bit wider than a 914...
I cut the cross bar in the middle then clamped each hinge half to the underside of the trunk seal channel, where that part will eventually be bolted. Then I tied the now overlapping crossbars to each other and determined center, then cut equal amounts off each side.
I then used the lathe to turn down a suitable bolt to make a slug that I plug welded into the cross bars. I'm determined to doing everything I can with TIG vs MIG and this was a good little project for that. So...A little TIG-ity, TIG and... one narrowed flip trunk hinge!
mb911
Oct 26 2017, 05:30 PM
Love it.. Its on my short list but gotta spend 400 on a set of refurbished rockers..
Krieger
Oct 26 2017, 10:57 PM
I like it!
tygaboy
Oct 28 2017, 09:08 AM
The chassis stiffening is nearly completed. Got the seat belt retractor mounts welded in.
tygaboy
Oct 28 2017, 09:09 AM
Final rear suspension tower reinforcement.
tygaboy
Oct 28 2017, 09:10 AM
Locking down the rear suspension-to-fire wall support pad.
tygaboy
Oct 28 2017, 09:11 AM
Final front suspension support tube.
tygaboy
Oct 28 2017, 03:10 PM
Finished installing the MadDog Motorsports front sway bar reinforcement plates.
I decided to to tidy up the rosette welds. Once it's back from blasting and epoxy prime, I'll seam seal around the perimeter. That'll all but disappear the wonky weld lines.
And the Elephant sway bar has their magical misalignment bushings. The bar literally swings, there's so little stiction. Really impressive.
tygaboy
Oct 28 2017, 03:11 PM
Brake line brackets installed and a little primer to protect things for now...
tygaboy
Oct 28 2017, 05:12 PM
Back to the flip trunk hinge.
I worked out the hinge attachment location. (Andy/Krieger was kind enough to let me measure and photograph his installation. Thanks Andy!)
tygaboy
Oct 28 2017, 05:14 PM
I bolted the trunk lid to the stock hinges and adjusted the fit.
Then, with the flip hinge in place and the trunk shut, I can climb under and mark where to install the threaded bosses in the outer stiffener panel of the trunk lid.
I still have final trimming and finishing on that one part of the hinge so pardon the sharp edges!
Krieger
Oct 28 2017, 05:27 PM
The similar color and your attention to detail will helps it look OEM!
Mueller
Oct 28 2017, 06:09 PM
That is going to be one impressive rear trunk lid. Cannot wait for videos of it in action.
Cracker
Oct 28 2017, 07:03 PM
Really slick Chris...the King of fabrication!!!
Tony
914forme
Oct 28 2017, 07:24 PM
Chris I would love to see the measurements, as I have the same setup in my shop, waiting.
tygaboy
Oct 28 2017, 10:51 PM
QUOTE(914forme @ Oct 28 2017, 06:24 PM)
Stephen -
Sure thing! In fact, I was thinking about you as I was doing this work, knowing you'd be doing the same install at some point. Once everything is in place and I know there's adequate adjustability and it all works as planned, I'll post some pics with measurements.
I can already tell you that to get things where I wanted them, the location of the hinge on my car is measuring out about 1/4" - 3/8" forward of where Andy has his.
The good news is that, near as I can tell so far, the specific location of the hinge (within maybe around 1" - 1 1/2"), isn't that critical. It'll be easier to document once I get it hooked up to the trunk lid and verify my assumptions about the geometry of this contraption!
tygaboy
Oct 29 2017, 11:59 AM
This morning was fabrication of the flip trunk threaded bosses and reinforcement plates that I'll plug weld onto the underside of the trunk, along the outer stiffeners.
tygaboy
Oct 29 2017, 12:01 PM
Plenty of room for adjustment!
tygaboy
Oct 29 2017, 12:02 PM
Now to measure for and cut the bosses, weld them to the plates, drill the reinforcement plates for rosette welding and get these installed on the trunk.
Mueller
Oct 29 2017, 10:35 PM
More great work I see you have been up to.
Don't worry, I'll make it look pretty enough to install on that work of art of yours!
Mueller
Oct 29 2017, 10:38 PM
double post... delete me .....
tygaboy
Oct 30 2017, 08:43 AM
QUOTE(Mueller @ Oct 29 2017, 09:35 PM)
Click to view attachmentSWEET! I have a 914 /6! (but man, that little ".2" really adds some hp!)
Mike,
Let's plan a time to meet up. I'd love for you to see my project and pick through the machining goodies, but I can get out your way, too. Let me know...
tygaboy
Oct 30 2017, 07:12 PM
I'm trying to sneak in an hour here and there to keep things moving along during the week. So this evening, I was able to get the flip trunk bosses cut down and welded to the reinforcement plates. Boring, yes. But it's all gotta be done.
914forme
Oct 31 2017, 08:17 AM
QUOTE(tygaboy @ Oct 29 2017, 12:51 AM)
Stephen -
Thank you Chris
ConeDodger
Oct 31 2017, 06:47 PM
tygaboy
Oct 31 2017, 07:18 PM
QUOTE(ConeDodger @ Oct 31 2017, 05:47 PM)
Rob,
Jealousy is such an unbecoming look on you...
ConeDodger
Oct 31 2017, 07:43 PM
QUOTE(tygaboy @ Oct 31 2017, 10:18 PM)
Rob,
What Chris? The welds are amazing!
tygaboy
Nov 4 2017, 10:42 AM
Final steps in the flip trunk.
First, figure out the location of the threaded bosses and drill for clearance.
