tnorthern
Apr 19 2005, 04:58 PM
I know a lot of guys are running electronic ignition in their cars but what are they running 'em with...
Right now I have a stock 2.0 rebuilt about 2k miles and 6years ago. I want to switch to electronic ignition with the ability to upgrade as I put more money into the motor.
Ultimately I would like to maintain Sunday drive reliabity while boosting horse power in the long run, most likely with a bigger type 4 engine. Resale value is not a huge issue for me since I have no real plans to sell the car in the future...
THIS time I am asking for advice so let the opinions fly
Mueller
Apr 19 2005, 05:07 PM
stock 2.0??
your options are:
replace points with pertronix or crane electronic trigger...no HP gain, just no need to set point gap and dwell, some people report smoother running engines...do a search on these, some people love thier pertronix, others think they are junk
a new or hotter coil*
new wires, stock or megabux types are available
then you can add a CDI box (mallory or MSD or whoever you want), this supposed* to help at idle and low rpms
any of these items are reversable so it will not affect the car being stock or not later on down the road......
*I have no real world experiance with these boxes
if you go with a bigger motor, then more than likely you'll not be able to run the stock FI, then you can do crankfire or install a MSD or Mallory distributor
Trekkor
Apr 19 2005, 10:57 PM
Ran Pertronix with the stock 2.0 FOUR.
Easy install, smoother starting and smoother top end.
No complaints. No maintenance.
On the SIX, MSD 6AL. This DRAMATICALLY improves starting and idle, as well as the whole power band while adding a programable rev limiter. A must for a carbed engine, I believe.
Adding Pertronix tomorrow to improve it further.
Coil mods to follow
KT
Mueller
Apr 19 2005, 11:05 PM
QUOTE |
Coil mods to follow |
Trek...I don't know if the Pertronics recommends a specific Ohm coil or not, but I'd double check the instructions just in case. On the Mallory Unilites (breaker point replacement module similar to the Pertronics), they want a specific ohm range, they say it'll help protect the module.
MSD sells specific coils for thier "systems", $28 at Summit Racing (MSD-8202), they also have a "high vibration" coil as well
I like to keep the same brand components together as much as possible....
Aaron Cox
Apr 19 2005, 11:08 PM
mallory unilote 1.4 to 3 ohm coil
pertronix has a how to pick a coil guide on thier website. tells you what ohmage you need......
Trekkor
Apr 19 2005, 11:21 PM
Thanks guys,
I'll start with my Blue coil for now. ( bringing a spare )
I'll research before I buy.
KT
ConeDodger
Apr 19 2005, 11:30 PM
Hey T! Glad to see you asking the questions and getting the answers.
I believe that no real horsepower or torque can be gained with ignition changes. But you can benefit from a more complete burn. Where this might help is on idle and starting as have already been mentioned but also if you were to change your cam or somehow increase your supply of fuel and air.
I still think the biggest bang for your buck is at the tail end of that car. BACKDATE YOUR EXHAUST. Sorry, did I say that really loud?
Next, if your not afraid to pull the motor go with Euro pistons.
These two things alone are about 5 HP each. You can actually feel 5 HP. No louder noise, its real....
Sorry I didn't see you at the RR Autocross this last weekend. You might have gotten to see my wife and sister-in-law flash me... I missed it. Probably good since I was driving the course!!!
Rob
Dave_Darling
Apr 20 2005, 01:25 PM
QUOTE (Aaron Cox @ Apr 19 2005, 09:08 PM) |
mallory unilote 1.4 to 3 ohm coil |
Will not work with D-jetronic fuel injection, unless you want to try Mueller's approach and "work some electronic wizardry"...
--DD
Aaron Cox
Apr 20 2005, 01:27 PM
QUOTE (Dave_Darling @ Apr 20 2005, 12:25 PM) |
QUOTE (Aaron Cox @ Apr 19 2005, 09:08 PM) | mallory unilote 1.4 to 3 ohm coil |
--DD |
not the point of my argument...
i was alluding to the fact that different systems require different coils.
Thx
Mueller
Apr 20 2005, 01:34 PM
--DD |
Dave,
Mallory sells the "Unilite" trigger module seperately if one wanted to use that instead of the pertronics in a stock dizzy to further complicate things
Since my car is getting the Link fuel/ignition computer I'm going to need a test subject with a 1.7 or 2.0 for the newest revision of trigger points...and suckers, I mean subjects
ArtechnikA
Apr 20 2005, 02:11 PM
QUOTE (trekkor @ Apr 20 2005, 12:21 AM) |
I'll research before I buy. |
QUOTE |
MSD sells specific coils for thier "systems", $28 at Summit Racing (MSD-8202), they also have a "high vibration" coil as well |
the thing about the "high-vibration" model is that it is the ONLY coil-shaped pulse transformer they make that is approved for mounting in aby other position than VERTICAL, SECONDARY TERMINAL UP.
if you have your coil mounted in the standard SIX location, you'll want one for this reason. i bought one to go with my last MSD-6AL and while the spark box is landfill (and good riddance) i do keep the coil as a spare, although i don't think the Crane LX-92 pulse transformer is likely to fail any time soon.
if you like the stock look, the Hi-Vibe is the way to go. i don't care about the look, hence the LX-92. MSD also has some blocky looking pulse transformers, but i donno anything about them.
oh - and to answer the question in the thread title -
Crane XR700 optical points replacement, HI-6 spark box with programmable retard module, Crane LX-92 pulse transformer on a stock 2,2 911E engine. but i'll use all the same stuff when the 2,8 goes in ... heh, heh, heh ...
HarveyH
Apr 21 2005, 05:55 AM
2056, cam (don't know which, PO's choice from a custon grind shop), 40 IDF's, stock 74 2L distributor, Pretronix, Crane HI-6, Crane PS-91 coil, and NGK platinum plugs @ 0.045".
Harvey
Mueller
Apr 21 2005, 08:44 AM
QUOTE (HarveyH @ Apr 21 2005, 04:55 AM) |
Harvey |
QUOTE |
stock 74 2L distributor |
a 1.8 dizzy or a new MSD or Mallory would be better suited to the carbed motor....better advance........
fiid
Apr 21 2005, 09:16 AM
I have a solution to the D-jet with mallory dizzy problem in the works.
I am running (running - HAH!) Ford EDIS with megasquirt on my subaru engine. it's 100% tuneable and hackable, but you need l33t 5k1llz to get it running. Fitting the EDIS trigger wheel to a TIV engine is tricky as well.
SGB
Apr 21 2005, 09:39 AM
I had Pertronix in a .050 for years & years. One less variable (points) to wonder about...
Last year got the Mallory Unilite. Man, what a difference. Tunability with advance springs helped top end performance, and new dizzy itself showed me how erratic the old Bosch had become. SS heat exchangers also helped noticably....
nebreitling
Apr 21 2005, 10:49 AM
tnorthern: go for a crane xr700 or a pertonix. i prefer the crane, but either will do the trick. the engine will probably run smoother, stay in tune longer, and require less maintenance.
HarveyH
Apr 21 2005, 11:26 AM
tnorthern
Apr 21 2005, 11:59 AM
Thanks for all the input guys, I think I am going to go with the Crane xr700 since I have a pertronix on my boat. Why not try something different? If I decide to swap to Carbs later in my quest for more power I would need to go to a Unitlite or similar correct?
tnorthern
Apr 21 2005, 12:17 PM
QUOTE |
Sorry I didn't see you at the RR Autocross this last weekend. |
Yeah I am sorry I missed you, I went on Saturday, but got there late. My brake squeal that I had been posting about on the PP boards reared again and there was no way I was going to try to AX
I met a couple of the guys from the board (trekkor and mcmark) and they were super cool as expected. My dad and I were laughing our ass off at nebreitling ripping the time ladies because they clearly were a little slow on figuring out the times... Once I get my car running right I will for sure be out there!
Oh yeah, I plan on doing the exhaust but I have way too many hobbies and the 914 can only get a portion of my hobby fund... Maybe I won't buy a new wakeboard this year... that saves $400
Mueller
QUOTE |
If I decide to swap to Carbs later in my quest for more power I would need to go to a Unitlite or similar correct? |
You don't "have" to get a new distributor, but if you want to maximize the potential of the engine, then yes, it would be a good idea.
If Fiids circuit works as planned, you can get an MSD or Mallory distributor right away.
My design worked, but it's not as robust and easy to install as it should be.....
tnorthern
Apr 21 2005, 12:25 PM
QUOTE |
If Fiids circuit works as planned, |
Umm... OK sounds great. I have no idea what that is do I need do a search on here to find more info? Sorry I am looking like a total newb right now.
Mueller
Apr 21 2005, 12:48 PM
for the D-jet cars, there is a pair of mechanical contact points near the bottom of the distributor, what these dois they complete a circuit (pull to ground) to tell the ECU to fire the injectors...very basic and simple and reliable for the most part. Near the base of the distributor, you'll see a connector with 3 pins, the center pin is ground, the other two are the trigger routes, one or the other will always be grounded when the car is running
The problem is that due to this triggering method, for most people, you had no other options but to run the factory distributor if you kept the factory fuel injection (D-Jet only)
there is nothing "wrong" with the factory stuff, this new circuit just opens up more options for people to change out there ignition to newer aftermarket items.
tnorthern
Apr 21 2005, 01:02 PM
Ok I understand it now that you said it in english. I knew that the dist had contact points for the FI and I knew that was something most owners overlook. So am I to gather from this that you either have or are developing an after market solution to this for us teeners? I am intrigued now. Would that be a bolt on solution for use with a new dist?
Mueller
Apr 21 2005, 01:08 PM
QUOTE (tnorthern @ Apr 21 2005, 12:02 PM) |
Ok I understand it now that you said it in english. I knew that the dist had contact points for the FI and I knew that was something most owners overlook. So am I to gather from this that you either have or are developing an after market solution to this for us teeners? I am intrigued now. Would that be a bolt on solution for use with a new dist? |
here is a picture of my 1st prototype.....it works, but for the average person, it would be a PITA to implement
the design Fiid is working on will be trigger off of the coil and not have the goofy optics as mince does (as the L-Jet is)..his will consist of a flip-flop circuit(s) to trigger the ECU
mickey mouse engineering works
