Hello All!
I am going to begin the rust removal process on the front of the car. The front window cowling is bad and I have a replacement but at the same time I would like to remove the fenders to eradicate the rust where the top of the fender meets the cowl.
While I am in there, I am going to remove the gas tank and clean-up underneath and detail anything else in the trunk that is necessary.
With removing the front fenders does the front end of the car need to be properly braced from front to back to limit sagging with the fenders removed? I would imagine it does but I want to hear from the 'Brain Trust' if I can just leave the car on jack stands while doing this work? I did not count on making a jig at this point but if I need to I suppose I should.......
Removing the fenders will make it easier to eliminate the warts and knock out a couple dings too.
Appreciate the help.
