This is a cut and paste of a thread I put on a Toyota truck forum
I'm getting no responses there, and I know there are a lot of good mechanics on this forum, so decided to repost it here for input:
HELP: starter not activating, solenoid clicks
So this was an intermittent problem for me for about a month. Each time in the past I would wait a minute and try again with a successful start
then last Thursday (in the garage luckily) I turned the key and heard the click, with no good outcome
This Truck is an 86 4x4 with automatic transmission
I bought a starter, foolishly thinking the solenoid had failed and didn't bother to test anything
guess what, the new starter didn't work either
I began testing things and found that the solenoid wire was only sending 11.6V when the key was in the start position
when I jump a 12.5V battery wire directly to the solenoid it cranks as it should
So I started tracing the wire circuit to see where I was loosing voltage
I discovered that the automatic truck has a neutral safety switch on the transmission
I tested and found it also was only receiving 11.6V at the switch wire
next I pulled the ignition switch
at the switch wiring, both of the power wires are registering 12.4V
when the key is turned to the run position, that voltage drops immediately to 11.6V
and in the start position it remains at the 11.6V reading.
so I'm leaning towards a circuit in the "run" position is putting enough draw on the battery to decrease the necessary 12V's from getting to the solenoid
oddly, and this may be a clue that I'm not smart enough to figure out: when I disconnect the starter switch entirely and jump a 12V battery source to the solenoid wire as it exits the ignition switch, I still get the "click" without exciting the solenoid.
my first question:
what all is in the pathway of the solenoid wire at the switch?
I've discovered it goes through the neutral safety switch at the transmission
I've discovered it goes through a relay behind the glove box that clicks each time I apply power to that wire
is there any other system that it goes though I should be checking, and is there a way to test each of these items its passes though?
My second theory is still that something in the run circuit might be lowering the voltage before I engage the start position on the switch.
but weird that a direct 12V source to the solenoid circuit applied at the wire to the switch isn't exciting the solenoid
do I have 2 problems?
thanks for any help or tips
I'm pretty stuck and don't want to just buy more components (like I did the starter)
I don't know if there is a common failure point/component on these trucks I should be checking first?
brant
