QUOTE (Jeroen @ Apr 20 2005, 05:26 AM) |
when sideloaded, the design will now pivot over the top of the spring hat / bottom of the camberplate instead of the spherical bearing because of this, you will crush both the needle bearing and the spherical bearing and have the possibility of bending the shock shaft |
I'm not sure if the Ground Control camberplates are the same design as in the scetch below, but if they are, it's a crappy design IMO the upper spring hat is machined to a concave surface the bottom of the camberplate is machined to a mirror convex surface these two contact (specially under load) supposedly, they did this to take the load off the spherical bearing because everything binds up now, they incorporated a needle bearing in the spring hat so you can still steer the car (axial movement of the strut) when sideloaded, the design will now pivot over the top of the spring hat / bottom of the camberplate instead of the spherical bearing because of this, you will crush both the needle bearing and the spherical bearing and have the possibility of bending the shock shaft it totally defeats the purpose of a uni-ball setup (friction/binding free movement) |
