Ok, I'm putting my pedal assembly in and because I did not remove it, I do not know where the 2 wires go for the brake switch. There is a 3 wire plug and a 1 wire plug, anyone know which one goes where.
SOT anyone notice that the clutch return spring wants to depress the pedal rather than keep it in the up position ?? I reworked the spring on mine to hold true pedal up, forget just how now
ClayPerrine
Oct 21 2016, 11:35 AM
QUOTE(barefoot @ Oct 21 2016, 12:30 PM)
That is not such a good idea. The spring is there to hold tension on the cable. You now risk the clutch clevis falling out of the clutch arm.
