carcus
Oct 22 2016, 01:47 AM
I have the OEM center console clock, but it does not work, just lights up. I know they were Quartz, but do not know if they have a battery that I can open up the clock and replace. Is there a more modern clock that will match the car aftermarket in the same spot that looks VDO? I do not want to spend a ton of money for a clock in an old car...I think you guys get that.
dlkawashima
Oct 22 2016, 02:00 AM
I encourage you to try to fix it yourself, especially if you have a Type I clock. Follow the directions here:
http://www.pelicanparts.com/techarticles/m...lock_repair.htm
Ian Stott
Oct 22 2016, 04:39 AM
Is there a vendor where you can send it for repair?
Ian Stott
Moncton
Canada
GeorgeRud
Oct 22 2016, 08:52 AM
North Hollywood Speedometer does excellent work (though not always considered cheap).
914Sixer
Oct 22 2016, 08:50 PM
I have a NOS Audi movement that is a direct fit. I would recommend that you send it to NHS for replacement because it requires a SPECIAL LOW TEMPERATURE solider. Picture on request.
carcus
Oct 22 2016, 09:55 PM
Thanks for the great info and repair link. I need to do some research to find out if it is a type 1 or later type 2 VDO clock. I got the appearance console second hand and added the gauges. Not sure what year 914 they came out of.
