QUOTE(North Coast Jim @ Oct 26 2016, 12:07 PM)
QUOTE(North Coast Jim @ Oct 23 2016, 08:44 PM)
A new engine build required the engine to be removed from the car to replace a broken oil pump gasket on the new Mellling oil pump. As the engine was out I thought I'd do a double check of the valve clearances as this was one of the root causes issue of carb backfire/popping. Got a shop towel caught within the oil pump gears as I was hand turning the engine over by the blower fan. Broke the oil pump drive tang. Two pcs of the drive tang are now in the cam reservoir of the crankcase. Any chance of getting these things out without splitting the case again ???
Just sick over this development
Tried a vacuum fixture I made which separated oil before my vacuum source. Was able to get my pick up under the cam and around the area within the crankcase. No broken pcs found. Gave up and am prepping the motor to split the case. Goes back to the builder tomorrow. Stupid stupid me now lighter in the wallet,
I would leave them they are to big to cause any harm,they will fall to the bottom of the crankcase,they are magnetic u could fish them out .
However I'am at a loss to see how this would happen,a shop towel causing the oil pump drive gear to shear??????
Please explain ,thanks.
