QUOTE(Dave_Darling @ Oct 24 2016, 05:27 PM)
Clay did the high-pressure-to-low-pressure thing on his wife's car. Which caught fire not long after, due in part to the pressure regulator failing and the float bowls overflowing onto the engine. You may recognize this as a symptom of a Very Bad Idea . If you're running carbs, use a low-pressure fuel pump.
There are several ways to relocate the pump.
One involves just moving the stock three-port pump to the front, usually near the steering rack. You have to run a new power wire from the factory location to the new pump location, and you need to do a little bit of Adapter Magic to deal with the different hose sizes. Specifically, the larger supply line through the tunnel--you need to go from the ~7mm ID "D" port of the pump to the ~9mm OD of the center tunnel supply line, and from that back down to the 7mm ID line that is plumbed to the engine. You can use brass plumbing supplies, or make up a fitting, or some other method that floats your boat.
Use rubber isolators to mount the pump, like in the factory location. You will either need to weld in some nuts to hold the stock-type mounts, or find a place you can access nuts on the back side of the panel, or fake up some other way to hold it. (E.g., rubber-lined hose clamp to something solid.)
If you go with the late-style two-port pump, some problems are the same. As in, you need to run the power wire to the new pump location, and you need some Adapter Magic to deal with the engine bay end of the supply line. The differences are the exact adapters you need to make up for the pump (the suction port is a different size from all the others) and the exact mounting of the pump on the car. The factory mount is a plate that gets bolted onto a hole in the bulkhead in front of the fuel tank. So you will need to locate where it should go, cut the holes, and deal with the fasteners. (Weld-nuts are probably good, riv-nuts probably will work, sheet metal screws or needing to get a wrench on the nut on the inside of the fuel tank compartment are not recommended.)
So you see that there is no one procedure for moving the pump, because there are a whole bunch of variables in how you can do it, depending on what parts you have and what way you want to do the conversion.
--DD
Thanks. I think if I do it, I would be using the new(er) (assuming it is good) two port pump. (which is on the plate already)
So to understand; the pump sits behind the plate in the same section as the gas tank, and the plate location allows you to service it from the trunk side?
If that is the case, that sounds like the best solution.
As for power, I guess I have some wiring to run so it may wait till later in the restoration since I need to get the engine in and running before I start taking the interior out. (Long story and crazy ordered restoration schedule)
