QUOTE(matchpoint @ Oct 24 2016, 08:52 PM)
I am in the process of locating a new windshield for my 1976 - 914 project. ProSource Glass International in MA has a clear windshield or a green tint windshield mfg by Sekurit in Finland.
Does anyone know if the OE window in 1976 was clear or did the car have a green tint option at order?
I am trying to keep the car original and not sure if I should use clear or green tint glass. My original pitted windshield is difficult to tell if it is clear or a slight green tint.
Anyone have any advice on the Sekurit vs the Chinese windshields. Looks like the Sekurit is right at $300 and the Chinese glass is at $200. I understand the Chinese glass has a poor fit at the upper windshield chrome trim because the Chinese glass does not have the upper glass bevel/bubble which makes for a poor trim chrome fit. The Sekurit I understand does have a the slight bubble/bevel at the glass top like the OE glass has which makes a good OE fit.
Thanks
IMHO & as others have said, take a pass on the Chinese junk .... errrr glass!
Sekurit was one of the OEM mfgrs. of glass for the 914 back in the day, so it should be correct & good quality for your replacement.
Your 76 could've had glass one of 3 ways (as with any 70-76 914/4 or -6):
1 - All Clear
2 - Tinted windshield with clear side glass
3 - "Tinted All Around" (except rear, which was always clear since it was protected)
(side note - rear glass was always clear, but could be had with rear defrost, & there would be an extra dash switch to the right of the steering column if so.)
The only ways to know which was correct on your car (or anyone else's reading this), would be to either look at the original window sticker list of options/equipment, or to get a COA from PCNA (unless you have one already).
PCA members get a discount, & if you mention seeing the Porsche/PCNA ad in "Panorama" magazine of $10 IIRC even for non-members, & if you have the window sticker you get a discount if you send them a copy (it eliminates much of their research time) as well. Call the PCNA 800# to order it.
If you're concerned with sun on a DD or pleasure use car, then you could still go with a tinted windshield for better driveability.
Note that even the clear glass has a slight greenish-blue tint in it, due to the microscopic plastic sheet embedded in the glass to make it into safety glass.
I would recco having a local known excellent quality glass installer or Porsche dealer order & install it for you, so it's done right & you're not on the hook if the glass is damaged. You might also want to have them order a new set of the plastic mounting pieces, & a new repro windshield trim set so it all looks & fits as new.
Good Luck!
Tom
