I was putting the engine tin back on the engine and though I should reattach wire/cable from the bellows to the flapper arm and check it for full operation.
I used a heat gun and it took about 30 seconds - video shortened a bit.
It starts out in cold engine mode (flaps diverting air away from cylinders and away from oil cooler). As it warms up it moves to full cooling mode (flaps diverting air across cylinders and oil cooler).
https://www.youtube.com/watch?v=fpTWUNm1Qn8
