QUOTE(Mark Henry @ Oct 28 2016, 02:17 AM)
I use a scissor lift table like in the link below.
You just need a 2x4 across the engine bar and a block to level the tranny. Only PITA is you have to remove the handle...no big deal
But I also use a two-post lift, so my car is level and I have no issues with the car not being high enough.
http://www.harborfreight.com/500-lb-capaci...cart-61405.htmlI also used the Harbor Freight hydraulic table. Worked like a charm with and without the exhaust mounted on the engine. It made this a one man job and no issues of the engine getting away from you. Had to jack up the car to get the proper height so I could wheel the engine in place. HB table is 9" high to the bed about the same for a jack system. I've used a hyd jack before on my 1st 914 engine pull years ago and that was NOT fun.
As for building the engine up from the short block I used the small Harbor Freight engine stand. Had to do a little grinding on the mounting bosses to keep them from crushing the tranny mounting flange but that part was easy.
