VIN 4732908491. Chassis 5039534
Original color L96D Silver Metallic
Original owner states that motor has been increased to 2.5L , 103mm pistons
Compression tested all cylinders within 93-96psi
Ignition upgraded to electronic
Dual Webers 44's?
External 2 row oil cooler
Frame stiffening kit
Rear adjustable Konis, spring rate unknown
Front suspension looks stock, torsion bar size unknown
SS brake lines
911 master cylinder
Front brakes ATE BMW, 3" spacing
Rear brakes stock
Front and rear stabilizers plus rear shock tower support
Converted to 5 bolt with spacers, front 1" thick, rear 3/4" thick
Wheels, Fuchs 7J-16 with 225/50-16 tires, needs new tires
Spare tire Fuchs 6J-16 with 205/55-16 tire
SS heat exchangers
Dash perfect as far as I can tell
VDO gauge block added, cylinder head temp, oil pressure, and oil temp. All function.
Windshield wiper motor weak
Windshield full gasket, not sealer and trim
2 tops, one has a sunroof
Fiberglass flares and molded front and rear bumpers, flares have some cracking
Floor pans are solid with the exceptions of seat mounting points, and lower firewall at heater tubes. Does not effect chassis at this time, but will need to be addressed at some point.
Hellhole is strong, looks to be reinforced, battery in stock location.
Front and rear trunks in very good condition
Short shift kit, transmission shifts great
Overall, car is extremely fast, shifts and stops great.
I am posting this for a friend, lost garage space. Car needs to go.
Listed at 10K, car located in South Florida.
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
